Charging 24 volt system off 12 volts >
Old 04-11-2005 | 09:37 PM
Default Charging 24 volt system off 12 volts
I want to install an inverter in my boat .My friend has one that use 24 volts .How can I use the 12 volt alt to recharge the batteries that run it.Thanks for the help
482 is offline
Old 04-13-2005 | 02:27 PM
Airpacker's Avatar
Default Re: Charging 24 volt system off 12 volts
Theoretically, you can't. You can make or buy a step up transformer that will will convert 12 to 24 but it will cut the amperage in half.
Airpacker is offline
David Stotz
Drives and Lower Units
6
09-18-2007 05:05 AM
cloudmaster_321
14
05-27-2005 10:58 PM
tmthunder
2
08-27-2004 09:48 PM
38cigmike
1
08-03-2004 01:05 PM
pro design
3
01-10-2003 11:53 PM
