MSD Knock sensor >
MSD Knock sensor
MSD Knock sensor
Old 04-13-2005 | 02:04 PM
Wobble's Avatar
SORE MEMBER
Default MSD Knock sensor
Has anyone tried the msd knock sensor on a boat motor?
here is a link http://www.msdignition.com/tool_8.htm
having detonated a fresh engine with probably bad gas I was considering this.
Wobble is offline
Old 04-13-2005 | 06:12 PM
Default Re: MSD Knock sensor
the msd when i looked at them wasnot set up for marine . i ended up getting some from Anson ,i got them thru gaffrig marine..did same thing with a melt down from a restricted fuel line fitting.. good luck
38tg is offline
Old 04-13-2005 | 08:41 PM
Turbojack's Avatar
Got one in boat. Problem is you can not hear it between the exhaust noise & the wind noise. There is an adjustment for sensivity but I have never felt is was right. When I cruise at 3K the gauge is going wild saying detonation. When I am WOT it does not show detonation. When I am running hard it is hard to look at it. Has it saved me from tearing up a motor? Nope!
Turbojack is offline
Old 04-13-2005 | 08:46 PM
rbtnt's Avatar
I run them on both engines with gauges and idiot lights. I had to try several different senders before I found a set that would not go off above 5700 rpm. This was before I found out that the torque on them is important.
I had one go off at 4000 rpm when a lifter quit working.
rbtnt is offline
Old 04-14-2005 | 09:07 AM
Wobble's Avatar
SORE MEMBER
rbtnt,
are you running the msd? if so do they have an external trigger for a pro-light. I found the unit that Livorsi sells (anson?) $600+. A little out of my budget. The MSD unit is about $170.00.
thanks guys.
Wobble is offline
Old 04-14-2005 | 10:00 PM
rbtnt's Avatar
Livorsi.
rbtnt is offline
Bajapred
1
06-06-2007 09:24 PM
chad1
8
08-19-2006 08:16 PM
Scott
6
03-21-2005 08:07 AM
Jeff Pierpont
0
01-28-2005 03:01 PM
ASD-6
5
01-25-2003 11:09 PM
