Trim pump: King Cobra vs Bravo One >
Old 04-14-2005 | 12:50 AM
tomas_wallin's Avatar
Default Trim pump: King Cobra vs Bravo One
Is it possible to use a trim pump from a 1991 King Cobra with a Bravo One.
Is it the same operating pressure etc.
I assume the hose connections won't fit but that is no biggie...
tomas_wallin is offline
Old 04-15-2005 | 01:45 AM
Default Re: Trim pump: King Cobra vs Bravo One
Noone?
Old 04-15-2005 | 08:40 AM
Wally's Avatar
Were doomed!
I dont see why not......if you get some adapters to hook up the pump correctly it should work. Both drives see the same type of force when opperating so i dont see why one would have a weaker pump then the other.....but what do i know!
-Wally
Wally is offline
Old 04-15-2005 | 09:27 PM
Scott B's Avatar
Went the other way, had to have new lines made with the Merc ends on em. Worked just fine....
Scott B is offline
Old 04-18-2005 | 02:59 PM
Ok, thanks alot!
carter38
Drives and Lower Units
4
08-22-2007 10:43 AM
CNC
2
06-10-2006 07:36 AM
SeaWeasel
2
07-21-2005 04:29 PM
Bam Bam
5
02-21-2003 07:52 PM
