Water pressure >
Water pressure
Water pressure
Old 04-14-2005 | 09:49 PM
Default Water pressure
Has anyone had an issue with Eddie Marine exhaust creating to much block pressure and causing a head gasket problem?
RBeyer is offline
Old 04-26-2005 | 05:48 PM
Strip Poker 388's Avatar
Rob
Default Re: Water pressure
Its the water presure high ??? Maybe it a casting flaw in the water ports in them?maybe the head gasket was allready going?
If it is restricting the water that much I would think it would be over 40psi
Strip Poker 388 is offline
Old 04-26-2005 | 07:03 PM
The Menace's Avatar
Should be no more than 10-13 lbs. You may be getting a little vapor block.
The Menace is offline
Old 04-26-2005 | 07:11 PM
Official OSO boat whore
It's common to change the exhaust out and have pressure problems. It's one of the things that should be checked as part of the installation. This problem would not be limited to just Eddie Marine. The engine will hold 25psi just fine. You are proably in the 40psi range.
Cord is offline
LostinBoston
18
03-26-2006 07:23 AM
BOATMAN302
3
02-28-2006 08:17 PM
Zanie
5
03-10-2005 10:58 AM
28Eliminator
11
06-22-2004 10:43 PM
merlin540
08-28-2002 05:45 PM
