starter replacement >
starter replacement
starter replacement
Old 04-20-2005 | 09:00 PM
Default starter replacement
Any body got any (good) ideas on how to change starboard starter in 94 32 Caliber. Access doesn't look good!
baja32hs is offline
Old 04-20-2005 | 09:05 PM
Dock Holiday's Avatar
Charter Member #34
Default Re: starter replacement
That's a great excuse to put the engine, check the coupler, clean the bilge, replace the bilge pump etc.
Other wise you need a twelve year old with long arms and muscle!
This fat boy cannot get down there!
Dock Holiday is offline
Old 04-21-2005 | 09:47 AM
Remove the exhaust manifold,
that should get you enough room.
JaayTeee is offline
Old 04-21-2005 | 09:56 AM
32 caliber's Avatar
cut a 12" X 12" hole below the starter in the hull. After replacing the starter get back to us on how to re-glass the hole in the hull.
32 caliber is offline
Old 04-21-2005 | 10:29 AM
TURBOED's Avatar
im laughing my a** off with the replies but you guys are cruel,now that we are on the topic i gotta say that i hate working on the 24,it really sucks and there is no room for anything so i imagine a twin setup is even worse but what i would do is what jt29 said,remove the exhaust manifold and it might give you some clearance,im doing the bilge pump now and it sucks.
TURBOED is offline
Old 04-21-2005 | 11:03 AM
BAJA342's Avatar
Charter Member #1251
baja2902003 cut a 12" X 12" hole below the starter in the hull. After replacing the starter get back to us on how to re-glass the hole in the hull.
Baja2902003,
That what it seems like I'll need to do to change the water impellers!!!
BAJA342 is offline
Old 04-21-2005 | 12:57 PM
32 caliber's Avatar
well 342, another way would be remove the boat from the drivetrain, but that may take awhile...
Old 04-21-2005 | 05:32 PM
BajaRunner's Avatar
I just did one and its a mofo. I am seriously thinking about paying to do the other.
BajaRunner is offline
Old 04-21-2005 | 06:16 PM
Charter Member #34
I would not pay someone to do the water pumps. The more you do them the easier they are to do.
We changed on out on the 35 Fountain I was on in the Florida Keys month before last in less than thirty minutes on the starboard engine in the water!
The first time I changed one out was on my 272 and it seemed impossible. Took over an hour. Then I got the 36, and now it is a combination sea water pump / fuel pump with an extra gasket and you have to change the oil in it.
I don't even think about it anymore. We carry a spare kit with us at all times!
After you have had the hoses off one time, they come off easier the next time, you just losen the belt, pull off the two hoses, take three bolts off and presto! Take the pump to your work bench, replaced the plastic housing and impeller, repeat the above steps in reverse order and your are done!
Put the extra $75.00 per pump the dealer would charge in your pocket for gasoline.
If I can do it anyone can do it.
Old 04-21-2005 | 08:27 PM
As what I would call the" new kid on the block" I deserve some of those replies.
I'll let you know how it goes!!
baja32hs is offline
