Engine bog while trimming outdrive >
Old 04-22-2005 | 09:54 AM
Default Engine bog while trimming outdrive
What causes ( I assume it's electrical) the engine to bog or cut out while trimming the outdrive up? Whenever I go to WOT It seems to kill the ignition when I hit the trim. Does anybody else have this problem?
kennyo is offline
Old 04-22-2005 | 11:07 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Default Re: Engine bog while trimming outdrive
can happen if batteries are real low or naginal condition
klaw is offline
Old 04-22-2005 | 11:58 AM
I had a problem like that quite a few
years ago.
Ended up being the wires to the
trim limit switch (on the side of the gimbal ring)
had worn the insulation off of them, and were
contacting the transom assy,
creating a direct short to ground whenever
the up trim was activated.
The only other thing I can think of would be
a shorted up solenoid.
JaayTeee is offline
Old 04-22-2005 | 06:49 PM
tmdog's Avatar
Like Klaw said. Bad battery. Had same thing happen to me.
tmdog is offline
Old 04-22-2005 | 07:14 PM
bowtie's Avatar
I've seen this problem caused by a bad coil several times. Also alt or battery. Trim limit wires can do this but usually blow the inline fuse off the trim pump first.
bowtie is offline
Old 04-22-2005 | 09:55 PM
CR's Marine Ser's Avatar
Clean up all of your ground's also on the distributor!
CR's Marine Ser is offline
Prater
01-23-2006 10:12 PM
Steve_H
11
07-24-2003 09:56 PM
KenD
2
11-16-2002 08:30 PM
22ADVANTAGE
2
07-08-2002 08:20 PM
blackhawk
05-20-2002 11:40 AM
