removable mudflaps..
Old 04-23-2005 | 09:11 PM
traviss's Avatar
Default removable mudflaps..
Looking for somthing to protect the front of my trailer and boat. Was looking into these Road wing mudflaps. Looks like a good setup.. anybody running these or any other setup like it...
http://cabelas.com/cabelas/en/templa...412&hasJS=true
thanks
travis
traviss is offline
Old 04-23-2005 | 10:02 PM
Default Re: removable mudflaps..
campingworld has them too at decent prices. I've considered one myself.
Rippem is offline
Old 04-23-2005 | 10:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
VERY happy with mine from www.mudflaps.com
Its expensive, but the only one you will ever need to buy as long as you stay with a 2" receiver, as it adjusts to each truck/load you are running. You cut and tap them the length you want when you first install, and then you can forever adjust them up and down with the arm, and in and out with the slides.
I painted mine to match my truck, and you can see them on BobbyB's dually as well. They make two sizes.
Attached Thumbnails removable mudflaps..-flap1.jpg   removable mudflaps..-flap2.jpg   removable mudflaps..-flap3.jpg
Sydwayz is offline
Old 04-24-2005 | 06:59 AM
If you go with the NK's the following link has them for $30 cheaper than everywhere else.
http://www.northerntool.com/webapp/w...81&R=200314981
353guy is offline
Old 04-24-2005 | 07:50 AM
traviss's Avatar
thanks for the input guys i will be buying one soon or get hard up and save some money and make my own
traviss is offline
Old 04-24-2005 | 02:31 PM
2112's Avatar
Sydwayz;
Don't the weight dist. bars prevent your compression brakes from working?
Travis, I have the ones you asked about. Easy to use and very effective.
2112 is offline
Old 04-24-2005 | 05:49 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
2112,
No they do not. Its a big misconception. You can't use traditional ANTI-SWAY bar(s) with Surge Brakes. You can use WD bars.
See these two threads for LOTS of info.
http://www.offshoreonly.com/forums/s...ribution+hitch (page 1)
http://www.offshoreonly.com/forums/s...ribution+hitch (page 2)
http://www.offshoreonly.com/forums/s...d.php?t=101431
Sydwayz is offline
Old 05-01-2005 | 04:02 PM
traviss's Avatar
Finished weldin mine, just need to paint and find some mudflaps... have $18 into it so far
traviss is offline
Old 05-01-2005 | 09:09 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Damn, thought that was a picture of mine at first. Same design. I did have a problem with the angled supports being in the way of both my plug in connector and I have to run my saftey cables threw the supports do to lack of planning.
I went the same route, home made. I bought a mudflap from a farm supply store and cut to fit. Mine goes past the truck tires on the outside and down to the ground. No rocks can get past it. Maybe a wind drag now! Under $20 completed.
US1 Fountain is offline
Old 05-02-2005 | 07:56 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Be careful having them TOO low. They will actually kick up rocks. The installation recommendations on mine were 2-3 inches from ground when loaded. That's why I like the Enkay setup as I can adjust (and do) on the fly.
Sydwayz is offline
