Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Best Method to Care for Imron >
Old 04-25-2005 | 10:03 AM
Default Best Method to Care for Imron
I've heard some conflicting recommendations about caring for Imron. The Imron on my boat appears to be very resilient to just about everything thrown at it over the years, but there are a few light stains, mostly from being under some Oak trees.
Can Imron be polished like gel or like automotive paint? Can some mild detergent, like "Softscrub" be used on it to remove stains? What about waxing to further protect it?
JohnJan is offline
Old 04-25-2005 | 11:52 PM
VIPER7's Avatar
Default Re: Best Method to Care for Imron
Imron is better to be compounded, waxed, or polished like automotive paint. Fiberglass gel coat compounds are to course for Imron and can leave scratches. To remove the stains try some polish or wax with a light abrasive in it. If this does not work you can try some automotive compounds and then polish or wax afterwards to remove the light scratches from the compound. *** If your Imron is metalic without any clearcoar cutting it to much with compounds will cause a difference in the metallic if you go very deep at all into the paint. Also, do not cut through clear coats.
VIPER7 is offline
Old 04-26-2005 | 06:45 AM
Catagory5's Avatar
http://www.performancecoatings.dupont.com/bowstreet5/webengine/dpc/common/Controller/Action!_pageDispatcher/InnerModel!dpc/modules/Login/OuterModel!dpc/common/Controller/InnerAction!visitorAction
Go right to the dupont sight
Catagory5 is offline
justinVIP
17
03-11-2005 08:00 AM
phughes69
07-08-2004 10:38 AM
offthefront
05-16-2004 09:07 PM
deboatmon
12-03-2003 12:03 PM
RLW
22
01-06-2003 07:31 PM
