Fixing chips in drives? >
Old 04-27-2005 | 11:42 AM
Rookie's Avatar
Default Fixing chips in drives?
I have 2 drives that I want to clean up. They have a bunch of chips and pits in them due to salt water. What is the easiset way to clean up the pits.
I was thinking of sanding down the drives, blasting the areas of the pits, to get them bare, and then mixing up JB weld and working it in like bondo, sand smooth, prime and paint.
Or should I use something else, epoxy, polyesther resin for fiberglass?
Opinions wanted.
Rookie is offline
Old 04-28-2005 | 08:23 PM
duunoit's Avatar
Default Re: Fixing chips in drives?
ttt, me too
duunoit is offline
Old 04-28-2005 | 09:27 PM
Auto paint supply places sell stuff called "metal 2 metal", it's aluminized bondo more or less. After using and smoothing use ppg dp series epoxy primer and then paint. It won't come off till you hit something else.
kennyo is offline
GLH
07-01-2008 06:24 AM
f_inscreenname
04-27-2008 04:08 PM
bidpro
09-08-2006 01:38 PM
exaeh007
Detailing, Painting, & Fiberglass
18
07-07-2005 05:02 AM
Rookie
1
04-28-2005 08:45 AM
