big tire/wheel upgrade for dually >
Old 05-01-2005 | 02:47 PM
b717200's Avatar
Thumbs up big tire/wheel upgrade for dually
I am thinking about putting some semi type wheels on my 02 Ford F-350. Have any of you guys had any negative experience with this or any maintenance issues that were caused by the upgrade ie. suspension problems, etc?
How much would some 22.5" alcoas lift the truck? It is a 4x4 does that affect any of this as well?
I hardly ever use the 4 wheel drive but do not want to affect the ability to do so. I know that semi type tires are less aggressive tread and ride a little stiffer but I dont think that will be an issue for the little time that I use the 4 wheel drive.
Where is the best place to buy some wheels and the adapters for the 8 to 10 lug conversion?
any and all help would be great.
Thanks guys.
b717200 is offline
Old 05-01-2005 | 03:10 PM
Sean H's Avatar
A to Z
Default Re: big tire/wheel upgrade for dually
http://www.dieselsitetoo.com/index.a...ROD&ProdID=132
Sean H is offline
Old 05-01-2005 | 03:20 PM
b717200's Avatar
Could not find anything larger than 19.5 here. I would like to go up to 22.5 so that it fills the wheelwell a little more, any ideas?
I saw one of these trucking shows on speed channel, and they had 22.5 that looked awesome, so I know it will work.
looks like it will cost about 4k by the time i am done.
any other ideas?
b717200 is offline
Old 05-01-2005 | 04:05 PM
dhlaw's Avatar
Like this......
Attached Thumbnails big tire/wheel upgrade for dually-adapters.jpg   big tire/wheel upgrade for dually-dodge1.jpg   big tire/wheel upgrade for dually-dsc02827.jpg
dhlaw is offline
Old 05-01-2005 | 04:28 PM
b717200's Avatar
Yeah yeah like that, like that.
info
info info
info info info
pretty please
b717200 is offline
Old 05-01-2005 | 05:05 PM
check here www.chromewheel.com wheels/ adapters or check here for direct bolt on hub and lug centric 19.5 and run a larger tire. www.brentzwheels.com you also have ricksonwheels as well.
JPD Motorsports is offline
Old 05-01-2005 | 08:36 PM
OSO's Avatar
OSO
call reds or gaw diesel in Miami, they are ford experts.
OSO is offline
Old 05-01-2005 | 10:14 PM
b717200's Avatar
would you happen to have a link or number?
thanks
b717200 is offline
Old 05-01-2005 | 10:23 PM
Sean H's Avatar
A to Z
305-696-9990 red's in miami
Sean H is offline
Old 05-02-2005 | 12:15 AM
Hot Duck's Avatar
When it comes time for a new truck, trade the F-350 in for a F-450 or F-550 and you'll get 19.5" wheels from the factory. Along with the larger wheels come larger brakes, larger axles, etc. Just an idea. I loved mine, but I had to sell it because I needed something a little bigger to legally tow the boat.
Attached Thumbnails big tire/wheel upgrade for dually-1.jpg
Hot Duck is offline
