HP500 merc/dart intake fitment? >
Old 05-02-2005 | 01:25 PM
mtgbiker's Avatar
Default HP500 merc/dart intake fitment?
Will a hp500 merc/dart intake physically fit a 454ci/420hp w/iron heads?
Has anyone ever flowed this intake to a 454ci 365/420hp head?
My goal is to use these intakes on a set of 800 cfm carbed 454ci motors built to @ 500-525hp via cams, pistons, head work and balanced crank assemblies.
mtgbiker is offline
Old 05-02-2005 | 01:55 PM
Default Re: HP500 merc/dart intake fitment?
The HP450 ( 454 based) used the
same dart intake as the HP500.
You should be able to get there from here
JaayTeee is offline
Old 05-02-2005 | 03:11 PM
mtgbiker's Avatar
I have also read about installing "wedges" in the heads of normally aspirated high hp 454 motors high rise single plane intakes with Iron heads .
Can someone explain the purpose of "wedges"?
mtgbiker is offline
Old 05-02-2005 | 03:39 PM
PatriYacht's Avatar
Jim V here on the board is the airflow guru that makes the wedges. Give him a call. My understanding is that they straighten the short side radius of the intake port and reduce the volume thereby increasing speed of the mixture. I think they are in the Great Lakes Caster race boat.
PatriYacht is offline
alecsammy
21
11-10-2008 12:07 PM
ls1nova
9
01-24-2008 11:02 AM
RickR
1
09-03-2003 06:48 PM
Budman
16
03-12-2003 09:01 AM
