Imco shorty
Old 05-11-2005 | 12:16 PM
Default Imco shorty
I've got a '02 280 Silencer and I'm toying with adding a Imco shorty lower.Someone was nice enough to answer this question last year but I never got back to 'em.Anyone try this?Thanks,BOB
Bob280Silencer is offline
Old 05-12-2005 | 04:18 PM
Default Re: Imco shorty
ALSO,what about an extension box?Anyone try one of those? Thanks,BOB
Old 05-16-2005 | 01:00 PM
ttt
Old 05-16-2005 | 07:50 PM
ROGMAN's Avatar
Bob,
I don't know about the extension box, but I would be carefull with the shortie. The PQ "X" dimension is already pretty high. I ended up adding a 1" drive spacer to dial my boat in.
ROGMAN is offline
Old 05-16-2005 | 10:56 PM
Jon,Did you add the spacer to the shortie or the stock bravo?My bravo had a spacer in it and the boat leaned so bad to the left,(torque steer)I had to drag a left tab to keep it straight.Took it out and the lean went away.Boat ran the same mph and was safer to run at speed.Talked to Mark at PQ today;he said PQ is pretty conservative with X.My prop shaft is 5.5 to 5.75 inches below the bottom.He also said the twin's had great success with the shorties but no data on the singles.Thanks,BOB
Old 05-17-2005 | 07:12 AM
ROGMAN's Avatar
Bob,
I added the spacer to the Bravo. My prop shaft was 4.25". My slip factor was off the charts. I picked up 5 mph with the spacer and stepped up to a 26 pitch prop.
Jon
ROGMAN is offline
Old 05-17-2005 | 09:13 AM
What year is your 280?Mark at PQ said they haven't changed the hull is years.4.25 is up there.My plan is a 2" shorty,then space it down 1".That should put it at 4.5 -4.75 with a five blade prop.I can borrow a shortie.After I try it,I'll get back to you.Thanks for your help.You must have been very happy with a 5 mph gain!! BOB
Old 05-17-2005 | 01:58 PM
ROGMAN's Avatar
Bob,
I have a 2000. PQ did some playing around with the "X" a few years ago. It's amazimg how much difference 1" can make in the drive height. It took me a while, but I got the boat dialed in just right.
I think I talked to you last year - didn't you punch out your engine to a 540?
Jon
ROGMAN is offline
Old 05-17-2005 | 11:07 PM
Jon,I sold the HP500 and built a 548.Makes around 650 hp.I had Cam Motion cams in Baton Rouge grind a cam,677 lb tq at 3400!Makes over 600 lb tq from 3100 to 4200.Gets up pretty quick.Lots o' fun.I'll be in touch after the 5 blade and shortie.BOB
Cat-n-Around
Swap Shop
12
12-06-2008 02:53 AM
aTX427
11
01-04-2005 07:36 PM
INDY27
4
04-23-2003 08:20 AM
Ralph Rast
0
08-31-2002 08:50 AM
Xtremeracing
05-17-2002 09:39 PM
