Issues with 1999 42 bottom? >
Old 05-11-2005 | 06:08 PM
Default Issues with 1999 42 bottom?
Is there any truth to the rumor that the 1999 42 ft bottom is not the best one compared to the later models? I have read here on OSO that they are all the same from 98 on but maybe someone knows the actual tweeks that the factory has done on the 42 from 1998 until now. I am specifically referring to handling/performance with 525HP/bravos, not big power.
I can't imagine Reggie not tweeking the bottom each and every year. Some years from 1998 to 2004 must be better than others.
I am considering such a boat and would like to flush out any first hand knowledge regarding this issue.
I am sure the 1999's work fine, I am trying to find out if the 2000 and later model works a little better with stock power.
jody165 is offline
Old 05-11-2005 | 09:02 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Default Re: Issues with 1999 42 bottom?
I had a 99 42ft Lightning and loved it.
mcraymond3 is offline
Old 05-12-2005 | 09:08 AM
Downtown42's Avatar
I'm sure you'll love it!
The new bottoms are flat at the steps, I think you have more aggressive lift, not sure. Your rear step sits higher than the front step. Mine are same height flat.
If it runs and drives , looks good then you're in.
Downtown42 is offline
Old 05-12-2005 | 02:16 PM
Thats a good question...I know I like the 97 steps and the 05's.
Back4More is offline
Old 05-12-2005 | 10:15 PM
later's Avatar
i think the bottoms changed quite a bit in the early step years 95-97 mid to late 98 they went to the big steps and i think they stayed the same until mid to late 04. then early to mid 05 they changed the bottom quite abit to reflect what they learned in the fastest v bottom persuit the steps on mid to present 05s are different then the 98-04 boats they seem to be placed firther back and the notch at transom is larger, and boats with big power seem to have a different step placement, i dont know any of this to be true just observation, also in 98 they changed the way the strakes end into the bottom of the boat and know they have gone back to the way they were in the early and mid 90s
later
later is offline
Old 05-12-2005 | 10:29 PM
Downtown42's Avatar
RUN HER...you'll love it..they all work good
dcroghan
6
08-06-2007 10:05 PM
Dredgeking
Skater
5
08-12-2004 04:17 PM
surfacetension
Fountain
3
02-14-2003 08:31 PM
fullthrottle42
Fountain
7
06-11-2002 05:16 PM
