prop shaft
Old 05-15-2005 | 06:23 PM
Default prop shaft
getting boat ready for season and noticed one prop shaft twisted, surprised boat is 32 fountain with 100 hrs with 415 hp, only out of water a few times with easy re entry, I thought bravoes where stronger than that.Has anyone run a boat with shaft twisted , does not vibrate and is straight
thks JMPH
JMPH is offline
Old 05-15-2005 | 06:37 PM
Dave1972's Avatar
Default Re: prop shaft
JMPH,
I had a twisted propshaft last year and mine was the same way. I wasn't sure how it got that way as I NEVER air out and if I ever have, it's been a very easy/stressfree re-entry. I had mine replaced...think about metal, it's not supposed to twist...it's soft there and at the best your prop will be gone....worst the shaft will twist off and tear up your case and prop will still be gone.
Are bravos weak? Well...they are the weakest link anyway...you might want to upgrade to IMCO shafts while you have the one replaced.
Let us know which direction you go!
Dave1972 is offline
Old 05-15-2005 | 06:53 PM
Thankks Dave for reply, do you know if IMCO is a direct replacement and is it more money than a merc
thks JMPH
JMPH is offline
Old 05-15-2005 | 07:19 PM
Dave1972's Avatar
IMCO can be a direct replacement depending on the products you go with. As for pricing it depends on who you deal with for a new propshaft. I believe the MERC part is upwards of $150 for the shaft. If you have a shop that will work with you, typically the MERC part will be cheaper. I guess it depends how much money you want to spend and if you are doing the work yourself or if you are having your local shop do it.
Dave1972 is offline
Old 05-15-2005 | 07:22 PM
Dave1972's Avatar
Here's what mine looked like before being replaced.
Dave1972 is offline
Old 05-15-2005 | 07:35 PM
Thatss exactly the same as mine, I can't still beleive it, I acually have boat for sale but am going to repair before that, I know freinds of mine with more power and heavier boats and this has never hapened. I used to run a long time ago trs's with 600 hp each and never hurt a prop shaft, mind you I was easy on it.
JMPH is offline
Old 05-21-2005 | 04:53 PM
where can you buy a merc shaft for 150, i was just quoted 425 for prop shaft and 400 for vertical shaft, if there is a place to buy them I would appreciate it.
thks JMPH
JMPH is offline
Old 05-22-2005 | 07:49 AM
Dave1972's Avatar
I bought mine used for around $150...put up another post and you should be able to find some help.
Dave1972 is offline
Old 05-22-2005 | 07:23 PM
Just took drive apart, dropped lower case and found twisted vertical drive shaft on spline at coupler, lookes like I need vertical lower drive shaft and prop shaft. If anyone has these for sale please post. Does anyone know where to buy U- joints other than merc.
thks JMPH
JMPH is offline
Old 05-22-2005 | 07:56 PM
johnnyboatman's Avatar
had the same problem 2weeks ago ordered new hardened shaft from cp, never got a cahnce to install it, twisted bottom, must of had a twisted upper also after after a of hammering the throttle the drive broke the uppers at 95mph, check the upper when doin the lower youll be money ahead
johnnyboatman is offline
