Upsize tires for Excursion
Old 05-17-2005 | 12:12 PM
Registered User
Default Upsize tires for Excursion
It's time for new rubber and I've always thought the 265's on the Ex looked tiny in those big wheel wells.
Anyone out there with experience on fitting larger wheel/tire combos on the Excursion? I'd prefer not to lift it but if I have to, I'd only want to go up slightly.
Chris Sunkin is offline
Old 05-17-2005 | 10:34 PM
Default Re: Upsize tires for Excursion
check out www.donahoeracing.com there is a link to a place that does superdutys I think www.superdutyhq.com they have a bunch of pics of the ex with and without lifts with different tire sizes as well.
JPD Motorsports is offline
Old 05-17-2005 | 10:54 PM
Panic Button's Avatar
Emerald Coast of Florida
I have 295's on stock rims and no lift. I haven't had any problems.
Panic Button is offline
Old 05-17-2005 | 11:42 PM
DirtyMoney's Avatar
I have 35x12.5x18's with f450 front springs and f 350 4"rear blocks. The 450 x springs as they are called actually improve the ride and raise the front end off of the bump stops. The Excursion will start riding on the stops after very few miles(poor spring rate for diesels) Here is a pic. Oh and no scrubbing.
Attached Thumbnails Upsize tires for Excursion-dsc_0030.jpg   Upsize tires for Excursion-dsc_0032.jpg
DirtyMoney is offline
Old 05-17-2005 | 11:44 PM
DirtyMoney's Avatar
Another add on well worth the money are the Helwig front and rear sway bars. Next purchase is new shocks and put f350 rear springs on to eliminate rear sag when towing.
Old 05-18-2005 | 06:42 AM
Registered User
That's my exact truck and exactly what I'm looking to do.
You just used the same model-year 450 spring? if I read correctly, there's an "x" spring? Different from a standard 450 spring? Did you have to do anthing different with the steering or the track bar?
How did it affect your towing? I have a big truck to pull the boat with but I use the Ex for the small boat/jetskis/whatever. Don't want to be all over the road. The stock Ex wanders like a drunken sailor. I have the OEM tires on it. I put Bridgestone REVO's on it and it was worse.
Old 05-18-2005 | 06:43 AM
Registered User
Did the swaybars help with wander? Any suggestions on shocks?
Old 05-18-2005 | 06:49 AM
Registered User
By the way, how much lift did you get? Also, did your mod level the truck? My Ex is about 1.5" lower in the front- I understand there are differences in ride stance, even within model years.
Old 05-18-2005 | 10:10 AM
masher44's Avatar
Do you get any rubbing in turns with that set up?
Looks bada$$ by the way
My 05 is awaiting some mods and just cant decide on what look I want....
masher44 is offline
Old 05-18-2005 | 11:00 AM
DirtyMoney's Avatar
How many miles??? What year??? Diesel??? Mine went up 3" front and 1.5" rear it now sits 1/2" lower in front than rear. I will prob use rancho 9000's or bilsteins. Sway bars and springs killed the wander and bounce from the front end. I can get the part #'s for the springs for you they cost like 125ea front and rear block and u bolt kit is about 100$
