427ci Small Block 934HP.. Sutphen30 heres your Big Stick
Sutphen30 I got your big stick
I bet you install your cams from the rear there so big
You will need ores to get this one on plane .I bet you would run this cam in your Viagra needing porcelain Tub
The cam is 278/304 at .050 Lift is 847/850 cut on a 115 and has a 1.6/1.7 rocker.Or is this cam to small for ya ?
It should put ya in that RPM band you like running your motors in
JC Perf [Jeff] sent me this dyno sheet on yesterdays pull . It only made 934 at8250rpm On Richie Zul's dyno. sutphen30 what pitch do ya think ya need with these motors?
Here is the dyno sheet on the motor JC built
He said it made more power today . Maybe he will chime in.
Hey Strip!!
The big boy was on here before but I am sure he is lickin his pillowby now. I am trying to stay awake so when I get on a plane for Cali at 6am I can go right to sleep...
Originally Posted by sutphen30
now your talking,,we changed the cam alittle,,took out .21199 off the ls,,,picked up huuuugeeee power,,tried reverse duration and that was a turd
,,,i'll be running some titanium 5 blades 26 pitch,,,might buzz them to a lowly 9900 rpm.
was making great power till we sucked the roll of duct tape from across the room.damn jc,,ritchie doped slapped him at that moment.
made jc walk around in his socks to mop up the oil,too.
that would be others,,i'll spin 30's to 9300RPM.
and still be able to dock.
i have the knowledge,experience and integrity to build it.
gotta love that hatchet idle.
The 30 pitch 10 inch dia.
Bill You still using that Sperm whale 10 weight oil in your motors
