Tech Tip - VALVE TIMING >
Old 05-19-2005 | 07:28 PM
KEPP's Avatar
Only the Best Will Do!
Default Tech Tip - VALVE TIMING
In an effort to simplify what actually happens inside a 4-stroke internal combustion engine, we invite you to “take a walk” inside a typical engine.
We will discuss valve events, piston position, overlap and centerlines. Although we do not have enough room to explain cam design in detail, we will clear up several of the most often misunderstood terms. We hope to give you a more clear understanding of what actually occurs in the operation of a four-stroke engine. We will graphically illustrate the relationship between all parts of the engine and to try to help you understand how the camshaft affects the power of the engine.
Download the attached PDF file to read or print the rest of this article.
File Type: pdf
KEPP is offline
Old 05-19-2005 | 11:34 PM
Default Re: Tech Tip - VALVE TIMING
Alas, I can't download it cause I'm a p.o.s. free member here
Can you upload it to yousendit.com and provide the link, I'll be sure to mirror it.
RichardCranium572 is offline
Old 05-19-2005 | 11:54 PM
Strip Poker 388's Avatar
Rob
Its 5 pages . Try there web site the info is there.
Strip Poker 388 is offline
Old 05-20-2005 | 12:06 AM
hillbilly24's Avatar
thanks for posting all this stuff, it is very informative and I'm sure is explaining alot of mysteries for alot of people.
hillbilly24 is offline
Old 05-20-2005 | 10:47 AM
KEPP's Avatar
We'll have all of the articles posted on the web site at www.keitheickert.com sometime later today. I'll post a direct link for you once they are available.
KEPP is offline
Old 05-20-2005 | 12:35 PM
KEPP's Avatar
The latest articles have now been added to the tech tips section of our web site. For those of you that asked you can now view the available articles at http://www.keitheickert.com/tech_support/default.htm
Watch for more informative pieces from the KE team!
KEPP is offline
Strip Poker 388
6
02-08-2006 12:41 PM
KEPP
1
05-19-2005 09:21 PM
KEPP
0
05-19-2005 02:39 PM
KEPP
0
05-19-2005 02:37 PM
KEPP
0
05-19-2005 02:34 PM
