GPS Recommendations?
Old 05-20-2005 | 11:34 AM
Default GPS Recommendations?
I'm putting a few toys on my 42 Lightning and I want to set her up with a nice GPS.
The removable panel Fountain gives is so skinny (vertically) that I don't think I can find a screen small enough to fit. I hesitate to put in a bracket mount with the concern that it will try to bounce all over the place in rough water.... although the built in antenna would be a big plus.
Do you guys use bracket mounts?
Thanks for the input.
Jnewton is offline
Old 05-20-2005 | 11:36 AM
NJSONIC's Avatar
Default Re: GPS Recommendations?
How big is the panel??
NJSONIC is offline
Old 05-20-2005 | 11:41 AM
Panel is 6 inches high, but maybe 5 or so clear space behind.
Jnewton is offline
Old 05-20-2005 | 11:42 AM
dyno's Avatar
Charter Member #655
Navman 5500I best deal around I bought mine from Brokenlegdave with the rebate its about $300 for a color plotter and yes i use the bracket.
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 05-20-2005 | 12:22 PM
Stormrider's Avatar
JC Performance Engines
garmin 276c, don't know the space available.
But the mount is on good.
Stormrider is offline
Old 05-20-2005 | 12:23 PM
waterheater's Avatar
Have a Garmin 182C mounted on a bracket, no problems
waterheater is offline
Old 05-20-2005 | 12:57 PM
Milord's Avatar
How is it? I bought the same one with a new chip and the fuel monitor thingy but haven't got the GPS yet.
Milord is offline
Old 05-20-2005 | 01:44 PM
East Coast B's Avatar
I was limited on space and went with the lowrance m68c which is a combo gps/depth sounder and very compact. Can mount on top of dash or in dash flush mount. Pretty neat setup if you don't have a lot of room..... I have it on top of the dash with velcro right now and am planning on flush mounting it when I redo the dash next winter. You can get the cutout template from their website and they have a gasket you can buy if you flush mount it.
Good luck!!!
East Coast B is offline
Old 05-20-2005 | 07:46 PM
HUSTLEthis's Avatar
We have the 182c and it works great...should have bought it years ago...
HUSTLEthis is offline
Old 05-20-2005 | 10:49 PM
MarkSmith's Avatar
How does this compare to the Garman 182c?
MarkSmith is offline
