bolt torque?
OK, the intake to cylinder head bolts are as follows...
the lower intake bolts get torqued to 124 inch lbs....
the the long intake bolts get torqued to 30 ft lbs....
and the plenum bolts get torqued to 159 inch lbs on a 454 MPI and 150 inch lbs on 454/502 MAG MPI's as well as 8.2 MPI's.
John
John
Originally Posted by GOODT
if your going to torque the rocker arm bolts then you need to find a competent shop in your area to do it for you because they dont get torqued they get adjusted
I have NON adjustable Hydraulic Roller 502 MPI
Looking at your tag line I would think that might have come to mind
sorry I wanst paying attn....... 1997 and older rockers are 45 lbs 1998 and newer are 40lbs
again sorry for the mistake
Thanks again for the help
Wayne
Thanks again guys .. Just torqued the last bolt on the plenum...So after work tomorrow me and my trusty fire extinguisher
will try to start the 502 up
John
John
Well, first off I am sorry to hear that you had a problem. Second I hope you read the reply as it says inch pounds verses foot pounds. Most torque wrenches have a conversion on it for inch to foot pounds. What was stated is from a Mercury manual.
John S.
John S.
