Sending Units >
Sending Units
Sending Units
Old 05-21-2005 | 06:57 PM
Elite Marine's Avatar
Default Sending Units
Are the oil temp sending units for different brand gauges matched to the gauges? I had Faria Gauges in my old boat, but Gaffrig Performance in the new boat. Sending unit remained in the engine when I swapped it to the new boat.
While running today with the gauge finally hooked up, my oil temp was reading 320+!!!! I shutdown and pulled the dipstick, it felt and smelled normal. I run a oil t-stat so it usually fluctuates between 180 and 215.
Thanks for answering such a basic/stupid question!!!
Elite Marine is offline
Old 05-21-2005 | 08:30 PM
Poorsche's Avatar
Default Re: Sending Units
I changed from VDO to Gaffrig/Livorsi guages with no proble EXCEPT the fuel guage. VDO uses a totally different resistance sceme than standard US fuel guages so I had to change the sender. Everything else came over A-OK.
Poorsche is offline
Old 05-21-2005 | 10:27 PM
I had a similar situation with a Stewart Warner oil pressure guage. The sender was for 80 PSI and I installed a 100 PSI guage. The sweep of the guage is the same for both so with the 100 PSI guage it appeared I was running like 90 PSI oil pressure. I installed an 80 PSI guage and the pressure was 65, which agreed with a mechanical guage. I later confirmed with SW that a 100 PSI sender was required with the 100 PSI guage.
WETTE VETTE is offline
Old 05-22-2005 | 02:02 AM
I had a VDO sensor on my engine a Gaffrig/Livorsi guage. It made the guage work in reverse.
Griff is offline
Old 05-22-2005 | 07:58 AM
I think I'll splurge on the $ 20.00 sending unit to eliminate the stark terror that I felt when I saw 320+ degrees of oil temp!!!
Old 05-22-2005 | 10:46 PM
RedDog382's Avatar
If you still have high oil temp with a properly calibrated sending unit, you may have an overfill condition. The overfilled oil will aerate and heat up more than non-aerated oil.
RedDog382 is offline
bowtye8
1
07-19-2008 04:56 PM
29scarab
6
07-10-2006 03:31 PM
fleg1
6
05-05-2005 10:13 PM
Active Mike
4
09-07-2004 10:52 PM
delsol
2
08-01-2003 02:08 PM
