731-741 or 502/502 cam? >
Old 05-22-2005 | 11:25 AM
migara422's Avatar
Default 731-741 or 502/502 cam?
Hi guys, i need some help, i have a 435 hp 502 gen vI and im about to update the engine. I just bought crane gold roller rockers with new springs also and i want to change the cam as well, i have read some of the post and this 3 cams are the most talked about for the 502, im running an 850 carb and have stainless marine long risers. Any help choosing any of this cams would be appreciated.
migara422 is offline
Old 05-22-2005 | 12:38 PM
Default Re: 731-741 or 502/502 cam?
If you are running stock heads either will work. How much RPM you want to turn will determine which cam. Likely the 731 will be the better of the two.
WETTE VETTE is offline
Old 05-22-2005 | 01:17 PM
migara422's Avatar
Thanks for the reply, i am running the stock rectangular heads, i just a cam that wil give me more hp in comparison with what i had, i thought this was a good idea since im changing springs and roller rockers, as for rmps, i want to get more if i could but i dont want to sacrifice the engine.
Old 05-22-2005 | 02:47 PM
I think there was a stock 470HP version of the 503 in the gen VI EFI motors. Maybe you could rebuild it to those specs and still get good reliablity? I thought Gen VI already had hydraulic roller cam istalled?
VI Mike is offline
Old 05-22-2005 | 08:30 PM
I would stick with the 731. It will make good power, and should keep you out of reversion problems.
PPlay33 is offline
Old 05-22-2005 | 09:02 PM
Prowler's Avatar
Charter Member #1472
the 731 pulls good up to 5400 rpm's,if you want or need more go with the 741.ben there done that,i'm running the 741,it works better for me.
Prowler is offline
Old 05-22-2005 | 10:02 PM
mikes280's Avatar
741 is the best of the two haverun it many times
mikes280 is offline
Old 05-22-2005 | 10:54 PM
migara422's Avatar
Thanks for the advise, what is the difference in hp between these cams versus the stock cam in the 502? and what realistic hp should i get by putting the roller rockers?
Old 05-23-2005 | 06:53 AM
Elite Marine's Avatar
How would either of these cams work in a blower application. Lower boost 5 - 7 PSI?
Where are the spec cards for these cams?
I am in the search for a new cam for my motor also.
Not trying to steal your thread Migara422!!
Elite Marine is offline
Old 05-23-2005 | 07:35 AM
jdnca1's Avatar
How many rpm do you want to turn Pantera?
jdnca1 is offline
