help...blower surge >
help...blower surge
help...blower surge
Old 05-23-2005 | 12:21 PM
JLANE's Avatar
Default help...blower surge
I need some help. I have a Fountain with twin 502's. These engines have fuel injected B&M 250 Blowers. The starboard engine runs great very little blower surge and idles around 7-800....I can live with that, the port engine can only idle at 1200-1300 and has alot of blower surge anything under that. Under load they they both idle great. One other thing both engines seem to run a little fat which I don't understand because the fuel injection should compensate for altitude,air density, and temperature should it not???
Any ideas would be greatly appreciated????
JLANE is offline
Old 05-24-2005 | 12:46 PM
JLANE's Avatar
Default Re: help...blower surge
Originally Posted by sutphen30
who' efi system,,are you using oxygen sensors?sounds like the fuel maps need to be trimmed,,also whats the base/ignition map timing at??do you have the capability or want to program the ecu's.
I'd like to think I can fix anything but I think I'm over my head.
The B&M system uses the port injection from the 502 MPI. It has a B&M adjustable fuel regulator mounted in the manifold under the blower and purple B&M something or other that plugs into the wiring harness or maybe thats the ECU. It uses the stock fuel system.... Total timing is 30.
As this is my first fuel injected anything my knowledge would fit in a thimble but shouldn't the ECU adjust itself. For like temp, alt, air/fuel mix.... stuff like that.
Any help/advise would e greatly appreciated.
Jason
JLANE is offline
Old 05-24-2005 | 12:55 PM
JLANE's Avatar
Originally Posted by Stingray69
Lean is not your friend.
Check for a vacuum leak.
Lean is like my last 2 wifes they both cost me nothing but money.
To check for a vacuum leak where and how do you recommend I start. I started sprayed carb clean around the manifold but I didn't notice a difference in the way it ran. And unfortunetly no one up here has any experience with boating anything. So I'm kind of on my own.
Any advise would be great.
Jason
JLANE is offline
Old 05-24-2005 | 01:14 PM
I believe blower surge is attributed to a lean idle condition. Maybe you can tweak your fuel pressure up a bit and see what happens. Make sure you have fresh plugs in the motor as well. I just helped out a buddy with a stock 502 EFI and couldn't even set the timing the thing ran so bad. Installed fresh plugs and it ran like a ***** cat! His plugs were the original plugs in a 1999 motor.
WETTE VETTE is offline
Old 05-24-2005 | 01:15 PM
I guess Sutphen beat me to it!
Old 05-24-2005 | 01:40 PM
JLANE's Avatar
i'd run the motor for awhile(about 5min) and just let it surge.turn off and read the plugs.if white=lean,richen up,,black/sooty=rich,lean it out,,do this with the adj fuel reg.hopefully this will help.
who'd you buy this from??any instructions,,where the ecu's reprogrammed?
Thanks Guys I really appreciate the help.... although I'm a little baffled. How does adjusting the fuel presure change the richness of the motor???
Thanx
Finding a sharp corner to bang my head on
JLANE is offline
Old 05-24-2005 | 02:37 PM
The ECU is preset and does not adjust with conditions. It does not monitor conditions. It has a programmed fuel curve that will remain constant.
That is, if it merc one or similar.
Griff is offline
Old 05-24-2005 | 02:46 PM
tssteph's Avatar
Are their fuel pressure gauges for each motor? If not get some..... Boost gauges will also help. That is the first set of information needed. I have been doing a ton of reading on this topic as I have been chasing my own fuel related issues myself. I now think I have a good handle on what my problems are.
Important things to know:
Fuel pressure at idle
Fuel pressure under boost check this when everything else if correct
Timing, inital and total
Boost at WOT check this when everything else if correct
Vacumn at idle
All of this information with a comparison between motors and you will figure out what is going on.
tssteph is offline
Old 05-24-2005 | 04:15 PM
JLANE's Avatar
Vacumn at idle
Thanks a bunch... Let me get this information and I'll let you know...
Jason
JLANE is offline
Old 05-25-2005 | 09:24 AM
meckmotion's Avatar
i also have a 1990 35 fountain lightning with 502s. How old is your boat and how fast are you running?
meckmotion is offline
