Particles in Bravo 1 Drive Oil ? >
Old 05-27-2005 | 11:39 AM
Dusty Times's Avatar
Default Particles in Bravo 1 Drive Oil ?
What is permitible for particles in Bravo 1 drive fluid?
Must be brass because not much is magnetic or holding to the magnetic plug.
Dusty Times is offline
Old 05-27-2005 | 03:13 PM
Default Re: Particles in Bravo 1 Drive Oil ?
These are pre XR drives. I'm just changing the fluid and wanting to make sure everything is OK. Don't want to wait till it self destructs.
Old 05-27-2005 | 06:03 PM
Strip Poker 388's Avatar
Rob
Sounds like clutch cone[race] material in the forward or reverse gear.
Strip Poker 388 is offline
Old 05-27-2005 | 11:11 PM
It was just a very fine amount. I was assuming from the cluthes also but wasn't sure how much was normal.
Old 05-27-2005 | 11:28 PM
Rob
What hp motors do ya have ?
My Scarab with 828hp did not have any in it .One of The BMax's on the Hustler does .
Old 05-28-2005 | 12:50 AM
Mr Gadgets's Avatar
Charter Member #601
Dusty, the brass comes from the rings on the gears that wear on the shift fork. Not too harmful, but change your oil more often. If you see fuzz on the magnet, then wear is evident. If you feel chunks on the lower magnet the lower gears are done! If you feel chunks on the upper magnet you already are too late!! Just my experience..
Dick
Mr Gadgets is offline
Old 05-28-2005 | 11:29 AM
Thanks,
They are 500 efi's in a 38' Donzi. It was very minimal (had to look twice to even notice) but I'm pretty anal and always want to make sure everything is ok.
Old 07-13-2008 | 08:42 PM
25 hors la loi's Avatar
Originally Posted by Mr Gadgets
If you feel chunks on the lower magnet the lower gears are done! Just my experience..
Dick
20 hrs Dick , and i found chunks on the lower magnet , i will post picture tomorow morning , do you think my upper is ok ? , because the magnet there are fine (no chunky there)
Christian
25 hors la loi is offline
Old 07-13-2008 | 11:06 PM
Mr Gadgets's Avatar
Charter Member #601
Any time you get metal particles on the magnet, it means they are traveling through the preloaded tappered bearings and causing some damage. How much is hard to tell without disassembling them and checking. When preload goes away due to wear, then lash gets loose and things start to break.
Like I say, it is hard to tell without looking, but I have know people to washout the upper with mineral spirits and run it. How much power are you running and what kind of prop? Seems merc is making things weaker now a days.. Not the first set of lower gears that give up after 20hrs.
Lets see some pics..
Dick
Old 07-13-2008 | 11:25 PM
racesdad's Avatar
you should be fine. when i was with donzi we changed gear lube every 2 races to be safe. normal wear, always keep an eye on them though
racesdad is offline
