Strange noises >
Strange noises
Strange noises
Old 05-30-2005 | 03:10 PM
Codered's Avatar
Default Strange noises
Went out in a buddies new boat yesterday, would rather not say what make, it has a pair of 525's with the ITS set up. Nice set up and runs fine but there seems to be a noise coming from the engine compartment, sounds like water slapping against the hull or a broken u joint. Is a unconventional noise normal with this setup.
Codered is offline
Old 05-30-2005 | 04:16 PM
Downtown42's Avatar
Default Re: Strange noises
Did you open up the hatches and check anything? Do noises stop when idling?
Downtown42 is offline
Old 05-30-2005 | 09:05 PM
Codered's Avatar
yes I investigated the best I could the noise is there in gear and out of gear at idle
Codered is offline
Old 05-30-2005 | 09:13 PM
could be the internal flapper in the thru hull exhaust. If it has thru hull exhaust and it doesn't have the rubber flappers on the outside they are prob. internal. They will make all kinds of noise on some brands. If your boat has mufflers or baffles in the pipes it's prob. something else.
rdp145 is offline
Old 05-31-2005 | 10:41 AM
it's the internal flappers, they make a freakin racket
Dangerous Dave is offline
Old 05-31-2005 | 08:07 PM
Codered's Avatar
I gave the flappers consideration and then forgot all about them . I will check them the next time we go out. THANKS for the input much appreciated
Codered is offline
gdfatha
03-23-2006 02:17 PM
Poorsche
2
09-16-2005 01:07 PM
CC247
10
09-15-2005 02:54 PM
Jayl13
14
04-22-2002 08:23 PM
