Need a New Boat Lift.
Old 06-02-2005 | 01:19 PM
GrogBoy's Avatar
Default Need a New Boat Lift.
Good afternoon all ! New to this forum, looks pretty cool though. Over the holiday weekend I had the boat on and off of the lift about 5 times and she finally gave out. It's pretty old and the motor just burned out. The galvanized steel beams are very old and starting to rust thru also. It's just time to replace it. My contractor gave me a couple of quotes for two different lifts, and I'm getting the one with the remote this time ! The prices, power & capasity are very close but which brand should I go with ? He gave me a quote for a "Davit Master" lift and one for an "ABL" lift. Which one is better ? The "Davit Master" is about $250.00 cheaper, but $$$ is not the issue. I want quality that will last for years. I've heard a few good things about "Davit Master" before but not anything about "ABL". Any advise would be appreciated. Thanks ! ! !
GrogBoy !
GrogBoy is offline
Old 06-02-2005 | 02:28 PM
mr_velocity's Avatar
Default Re: Need a New Boat Lift.
Hi-Tide aluminum lifts, capacities to 120,000 lbs
mr_velocity is offline
Old 06-02-2005 | 02:31 PM
DanB's Avatar
Charter Member #71
How big a lift are you looking for? Weight? Type?
DanB is offline
Old 06-02-2005 | 02:40 PM
GrogBoy's Avatar
I'm looking for a CRADDLE LIFT that can lift 10,000lbs at about 8-9 feet per minute. I have a 26 Donzi ZX.
GrogBoy is offline
Old 06-02-2005 | 04:44 PM
Tim G.'s Avatar
Performance Boat Center
GB-
I was in the lift business here in FL for awhile...(Sunstream) See the advertiser/sponsor links page.
As far as piling lifts go.. I'd say Golden is top notch, followed by Hi Tide...
Both of which are built in FL, not far from St.Pete.
Do your homework on what is out there....
I'll be at the Miami boat show tomorrow...I'll see who's there and what they've got....
Check pricing vs capacity.. The cost diff between a 10,000 and 14,000 piling lift may not be too much...
Are your pilings still good? Are you sure????
TIM G.
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 06-02-2005 | 05:02 PM
el indio's Avatar
tim g the lift you had at the ft. lauderdale race 2 years ago was about the best i have seen.............flipping the floation with a remote..............simple and effective.....m.m............
el indio is offline
Old 06-02-2005 | 05:31 PM
Tim G.'s Avatar
Yep,
Sunstream is doing very well. The products were/are very good. Pricey, but top notch... I did one 18,000lb lift for a Fountain 38TE for $25k!!! Awesome setup.
Floatlifts are good, but honestly, I liked the Sunlift better.
The Sunlift was the one we used for the trophy stage...
Tim Gallagher
[email protected]
954-809-8739
Tim G. is offline
Old 06-03-2005 | 07:10 AM
GrogBoy's Avatar
Not sure I have heard of a Float Lift. What, is it some kind of an inflatable or something ? I only have about 11-12 feet of width to work with. How big is this thing ?
GrogBoy is offline
Old 06-03-2005 | 07:17 AM
el indio's Avatar
the sunstream is deffintly worth looking at.i was impressed with the mechanical engineering.ingenius.....mark...........
el indio is offline
Old 06-03-2005 | 08:02 AM
Tim G.'s Avatar
GB
www.sunstreamcorp.com
the 10,000lb Floatlift measures 24' long, and needs about 13' of slip width.
OSO Steve has a 10,000lb lift under the Gladiator, and a 6,000lb lift under the 24' Spectre....
The Floatlift uses Hard, solid floats, and hydraulics to lower the chassis into the water.
You may also be a candidate for the Sunlift... It sits on four footpads, right on the bottom.
I did a pile of these things in Siesta Key....
The 10,000lb Sunlift is available with a fully adjustable cradle to give the boat good support, much better than a piling lift ever can...
FYI, they have an XR model in the 10,000lb that has a taller lifting stroke.. I think it was 7' rather than 5'.
The sales guy in your area is Joe Larson. Tell him Tim G. sent you and he'll hook you up with a strong deal.
Remote: Yes
Speed: Yes- You're in the water in 40 seconds!
TIM G.
Tim Gallagher
[email protected]
954-809-8739
Tim G. is offline
