Cable steering question
Old 06-03-2005 | 06:43 PM
onesickpantera's Avatar
Default Cable steering question
I have quite a bit of play at the helm and I know nothing about this cable sytem. My other boats had internal hydraulic or full external. Is there adjustments that can be made or do I just replace the whole cable? If so how do you replace the cable?
I'm going to full hydraulic over the winter but want the boat safe for this year.
onesickpantera is offline
Old 06-03-2005 | 07:24 PM
n2boatn2's Avatar
Default Re: Cable steering question
I have a similar problem I tried 4 blades and the boat went crazy at wot takes a little jerk to the right and then returns to its normal place when you slow down I'm thinking maybe a Gimbel problem.
n2boatn2 is offline
Old 06-03-2005 | 09:39 PM
Mine is definitely in the steering. My gimbal(if that's what Volvo calls it) assy is solid as a rock.
I'm thinking I have a stretched/worn out cable. I guess I need to take the helm apart and see what makes it tick.
All I know is it's a shi**y system.
Old 06-03-2005 | 09:52 PM
el indio's Avatar
for single cable try a cable with opening at helm.......like a second station steering cable..............with no first station.............m.m.........
el indio is offline
Old 06-03-2005 | 10:59 PM
Well, since I have to have my azz up at 7am I'm not drinking tonight. Went out and took the back of the helm off. Looks like the cable wraps around a pulley and then into a "tube" which I am assuming is for the excess cable as the wheel turns.
Well the cable itself moves immediately when you turn the wheel. But it takes about 3/4" of pulley movement before it moves the drive. I'm guessing the other end of the cable goes into the hydraulic cylinder and puts pressure against it and that's how the cylinder moves in or out.
So, if the cable is stretched would this cause this play? My guess is yes but then again I am hoping that this is the problem. Here's a pic of the back of the helm.
Old 06-04-2005 | 12:43 PM
Pantera1's Avatar
First place you usually get some slop is the top steering arm to gimbal joint. Get inside the boat and watch it while someone on the outside moves the lower left and right.. Cable steering is safe to a certain speed but will always give feedback to the wheel ..hydraulic doesnt..
Pantera1 is offline
Old 06-04-2005 | 04:09 PM
There is zero slop in the gimbal ring, tiller, steering arm, etc. My last boat had a lot of slop at the gimbal and I had it repaired and put full hydraulic on it.
I move the wheel, the cable moves(you can see it) but the steering doesn't right away.
Old 06-05-2005 | 11:22 AM
Pantera1's Avatar
Man id just order a seastar hydraulic setup , and be done with it .
Pantera1 is offline
Old 06-05-2005 | 07:14 PM
I'm not going to waste my time with anything internal. Looks like the play I have is normal. I'll live with it until I go full hydraulic external.
Old 06-18-2005 | 08:24 PM
robyw1's Avatar
I have noticed mine has a little cable movement too. I wish I knew how to adjust this out if possible. Any reccomendations short of going full hydraulic steering?
Roby
robyw1 is offline
Carlo
Cigarette
0
07-10-2008 02:53 PM
Cigaretteski
Cigarette
2
05-18-2008 11:44 AM
AIR TIME
6
01-05-2007 06:26 PM
Smitty
Baja
3
08-07-2003 04:06 PM
Smitty
3
08-07-2003 04:05 PM
