500efi w/Vortech SC's...pro's/con's >
Old 06-08-2005 | 12:19 AM
Cash Bar's Avatar
Mod Squad Enforcer
Default 500efi w/Vortech SC's...pro's/con's
I'm considering a boat w500efi's and Vortech SC's. I just needed some info on what to expect.
The boat also has Imco upgraded XR's on ITS boxes.
Thanks for any help.
Greg
www.gregsellswaterfront.com
Cash Bar is offline
Old 06-08-2005 | 12:31 AM
Outdrive1's Avatar
Masher touches my
Default Re: 500efi w/Vortech SC's...pro's/con's
AZSM set mine up, not a hp500, just a 502 mpi. I did the fuel kit with as well, no problems yet except for destroying a Bravo drive.
Attached Thumbnails 500efi w/Vortech SC's...pro's/con's-resized-motor.jpg
Outdrive1 is offline
Old 06-08-2005 | 10:50 AM
Badkachina, that looks nice all polished!
Cashbar, which engine/kit? The black one like above or the HP500EFI (blue). In either case, find out what pulley is on the blower and what injectors were used.
The black one with stock injectors is good for about 570 HP. The blue one with 50 lb injectors is good for about 725 HP if the right pulley is used. You can make 725 with the black one too if you change some things.
With bigger intercooler and better airflow you can make 800 HP but you need to go UP to do it...These engines are also in front of IMCO drives and ITS. So far they are standing up to 760-780 ft-lbs.
Attached Thumbnails 500efi w/Vortech SC's...pro's/con's-starboard.jpg   500efi w/Vortech SC's...pro's/con's-port-iso.jpg   500efi w/Vortech SC's...pro's/con's-port.jpg
tomcat is offline
Old 06-08-2005 | 12:24 PM
Turbojack's Avatar
Pros-
More HP
Greater top speed,
Lower cruising RPM due to bigger prop.
Cons
Possible broken drive
Burn more fuel since you want to have the hammer down but would be less at cruise.
Slower or the same takeoff as before (prop will be bigger but you do not gain much HP or torque at low rpm to compansate for larger prop)
As someone's tag line is, "Once you go blown you will not go back"
Turbojack is offline
Old 06-08-2005 | 08:58 PM
Outdrive1's Avatar
Masher touches my
Thanks, thats pretty as well. I need an air cleaner made that will fit with with my headers (lightnings). They are too big to fit the Vortech cleaner on there so AZSM rigged up a little screen. I guess its ok, not like theres much dust on the lake but it's something I would eventually like to fix. Any ideas?
I could have gone with more boost since I changed the injectors, fuel pump, regulator etc and had the ecm redone but I wanted it to last.
Turbojack - It's slower out of hole, harder to get on plane, too much throttle and it breaks loose, once on plane the midrange and torque is awesome though. Breaking drives sucks, XZ now, when that goes I'll have someone beef up the upper for me, maybe Mr. Gadgets or Max Machine Worx.
Old 06-10-2005 | 01:07 AM
Cash Bar's Avatar
Mod Squad Enforcer
Thanks for the answers, here is a link to the boat. I believe there are engine pics that might give some more info....
http://www.offshoreonly.com/esvon/page-5430.html
Cash Bar is offline
Old 06-10-2005 | 08:52 AM
What props are on the boat? They look like three blades in the picture.
tomcat is offline
Old 06-10-2005 | 08:58 AM
Outdrive1's Avatar
Masher touches my
I thought Gladiators were usually staggered. Nice boat BTW.
Old 06-12-2005 | 11:06 PM
Cash Bar's Avatar
Mod Squad Enforcer
'02's(like OSO's) were side-by-side setups. The cockpit was a little bigger, which I like.
I do like the boat, and apparently the guy was a good friend of Skip Braver so all upkeep has been carefully monitored or done by Cig. just can't get enough info about long term care of the motors after I would purchase it. They were redone like 20 hrs ago.
Cash Bar is offline
Old 06-19-2005 | 12:25 PM
lucky strike's Avatar
32p / bravo 1 / 4 blades. Not sure if they are labbed.
LS JR.
lucky strike is offline
Chuck
02-26-2006 06:38 PM
CAP071
01-05-2006 07:16 PM
berns29scarab
6
09-01-2004 08:21 PM
HP-J
07-17-2003 07:49 PM
cougarman
09-27-2002 09:26 AM
