What is this for? >
What is this for?
What is this for?
Old 06-08-2005 | 07:33 AM
CR
Default What is this for?
On the bottom of the hull (2000) @ the stern just after the last step, there appears to be a water intake...however upon a little investigation the "intake grommet" simply connects to a 2 inch diameter hose which directly connects to another "grommet" on the port side adjacent to the bildge pump outlet. Does anyone know what this is for, what purpose does it serve?
Thank YOu
CR is offline
Old 06-08-2005 | 07:43 AM
pachangalpina's Avatar
Default Re: What is this for?
I know this has been discussed here before and I seem to remember that it was determined to aerate/ventilate the step. You may want to do a search of this forum for more info.
pachangalpina is offline
Old 06-08-2005 | 09:54 AM
Bad Girl's Avatar
That is right. It relieves any negative pressure that may build up in that pocket. I have those as well.
47 Lightning SE
Bad Girl is offline
Old 06-08-2005 | 10:24 AM
Reggie calls it " A Vacuum relief hose"
wcmarine is offline
Old 06-08-2005 | 12:23 PM
that sounds like a dick......and Bad Girl has one?????!!!!!
couldnt resist!!
pullmytrigger is offline
Old 06-08-2005 | 02:59 PM
dykstra's Avatar
dykstra is offline
Old 06-14-2005 | 08:52 PM
Hydrocruiser's Avatar
Arrow Re: What is this for?
a reverse fart hose...
...don't leave home without it.~
Hydrocruiser is offline
Old 06-14-2005 | 11:29 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Might not want to unhook it.
US1 Fountain is offline
