Performance gain predictions, 28 Daytona w/Raylar 496 HO's? >
Old 06-08-2005 | 03:19 PM
Harper220's Avatar
Default Performance gain predictions, 28 Daytona w/Raylar 496 HO's?
I've been kicking around adding the 496 HO Raylar kits. I need some input based on current stock numbers and possible expected gains after adding the kits.
Here's what I got: 28 Daytona 496 HO's XZ drives, no boxes and prop shafts even with bottom of boat running 29p Hydro P5X's.
Current #'s
3000 rpm's = 52 mph
3500 rpm's = 62 mph
4000 rpm's = 72 mph
4900-5000 = 90-92 mph WOT
The kits are said to raise the 496 HO to 525+ hp and 610 ft. lbs. torque @ 3800 rpm's. I definitely want the reliability with 87 octane and no super chargers.
I figured if the kits allowed me to add 3-4 pitches, I would see at least a 10 mph gain at 3000, 3500 and 4000 rpm's with the possibility of 12-15 mph at WOT.
Any predictions would be appreciated...
Harper220 is offline
Old 06-08-2005 | 03:27 PM
Sean H's Avatar
A to Z
Default Re: Performance gain predictions, 28 Daytona w/Raylar 496 HO's?
what does a 28 w/ 525's run? i would assume you would be real close to that...
and you might not end up adding as much prop as you think, but turning more rpm....
Sean H is offline
PARADOX
46
10-21-2007 08:57 AM
Harper220
25
12-09-2004 06:19 PM
Harper220
4
06-14-2004 09:25 AM
Harper220
5
02-17-2004 09:16 PM
KN
Sunsation
15
01-18-2002 12:21 AM
