Go Back  Offshoreonly.com > Owners Forum > Sonic
Built in dash cooler, does it work well?? >
Old 06-09-2005 | 10:17 AM
East Coast B's Avatar
Question Built in dash cooler, does it work well??
Does the built in cooler in the passenger dash work as well as a regular carry on cooler? Fabricated a plug for the drain hole which empty's out the side of the boat to keep the warm air out and the cold air/water in.
Just curious how well it works on the hot days or is it better used for storage???
East Coast B is offline
Old 06-09-2005 | 10:39 AM
Default Re: Built in dash cooler, does it work well??
i use mine all the time keep the plug out.i fill it with my favorite beverage put two bags of ice and i still have ice a day later.its fully insulated one of the great things from sonic. it's better than going to the cabin for a cold one.
sonic28 is offline
Old 06-09-2005 | 11:50 AM
shewbart's Avatar
I think it drains to the bilge not outside and that little opening will not make a difference. I love mine no cooler to get in the way but my 26 held a lot more than me 31.
shewbart is offline
Old 06-09-2005 | 11:55 AM
dyno's Avatar
Charter Member #655
Mine is T-ed into the line from the sink drains out the side of the boat not into the bilge I plugged them both off. Use the cooler as a glove box....
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 06-09-2005 | 12:18 PM
HiPerf2000's Avatar
I use mine every weekend. Works great. Best thing is that you just tell the passenger in the port bolster that you need a drink, and they don't have to go anywhere to get it. Safer than getting out of the bolster and going into the cabin when your running.
HiPerf2000 is offline
Old 06-09-2005 | 12:44 PM
Quiet Storm's Avatar
Good idea Don. I use mine as a glove box too so I thought the drain on the side of the boat was for the cooler also. My wife was cleaning the cooler and asked if she could just hose it out. I saw the drain and said yea no problem. She was happily spraying away and I didn't see anything coming out of the drain. Hmmmmmm????
I figured it out when I opened the engine hatch .
Did you get that part I sent?
Quiet Storm is offline
Old 06-09-2005 | 12:47 PM
Sounds like a good thing we got here!!!! Mine is piped to the outside, not sure if it's from factory or the previous owner did it. When I brought it home, had the hose in there to clean it out. Guess I'll have to find another place for my cleaning supplies!!!!
Sooooooooooooooo... The big question, with a bag or two of ice, just how much beer can one fit in these coolers.... not that I care, but I'm sure some of you have filled this sucker up!!!!
One of my many projects is to put a 12v outlet in my new passenger dash and cabin to handle the blender!!!
Old 06-09-2005 | 12:50 PM
dyno's Avatar
Charter Member #655
Yes Roger I got the part tahnks again so much I'm going to mount the new depth sounder with red bezel tomarrow after work I'll post some pics, thats the last thing I needed to up grade my dash!!!
dyno is offline
Old 06-09-2005 | 01:22 PM
HiPerf2000's Avatar
I'm able to fit a 30 pack and 1 small bag of ice in mine. not sure if there is a size difference between the 35's & 31's ?
Old 06-09-2005 | 02:57 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I used mine everytime out. As a matter of fact, mine used to hold ice for days and keep things cold, even in summer.
Sydwayz is offline
