How fast is your V Hull (try to be honest) >
Old 06-10-2005 | 11:45 PM
Dregsz's Avatar
Default How fast is your V Hull (try to be honest)
How fast is your V Hull (try to be honest).
What power are you using?
(post the boat size and weight).
Evan
Dregsz is offline
Old 06-11-2005 | 12:55 AM
FOUNTAINATLAST's Avatar
Default Re: How fast is your V Hull (try to be honest)
27" Fountain
496HO prop 24 pitch bravo
at Havasu 5300 RPM hitting limiter (needs 26 pitch) about 69 MPH (not gps)
At pleasant 5000 RPM about 65 MPH (not gps) alot higher elevation thats why the speed decrease.
FOUNTAINATLAST is offline
Old 06-11-2005 | 01:04 AM
Dregsz's Avatar
What is the elevation at Havasu?
Dregsz is offline
Old 06-11-2005 | 01:15 AM
35 Fountain Lightning ts
hp 500 efi flowed ported & polished dart heads
32 labbed B1 89 mph/gps
bobd is offline
Old 06-11-2005 | 02:17 AM
Elevation at Havasu is about 400 feet above sealevel, and at Pleasant about 2000 feet above sealevel
Old 06-11-2005 | 02:50 AM
RedDog382's Avatar
382 Fastech Formula 645 H.P. Sterlings through XR drives on Stellings extension boxes. Light fuel, 5 P.O.B. Non-labbed 28 Bravo's
Attached Thumbnails How fast is your V Hull (try to be honest)-videostill-013.jpg
RedDog382 is offline
Old 06-11-2005 | 04:12 AM
articfriends's Avatar
2000 baja 272-mid 80's last year,making another 200hp this year,should be mid 90's,4400lbs,procharged big block,Smitty
Attached Thumbnails How fast is your V Hull (try to be honest)-boat-tests-018.jpg
articfriends is offline
Old 06-11-2005 | 06:22 AM
offshoredrillin's Avatar
42 Cig Tiger 72-73.5 2 people half tank@5000 rpm hp500efi
Formula 311, 70 one person full tank gas @4800 rpm 502 magnum efi
offshoredrillin is offline
Old 06-11-2005 | 06:26 AM
OldSchool's Avatar
31' Cigarette Bullet 2 X 625HP 83 gps
38' Cigarette Top Gun 2 X 1240HP 109gps
OldSchool is offline
Old 06-11-2005 | 07:23 AM
Talking Re: How fast is your V Hull (try to be honest)
30' Phantom Sportster
677hp On Innovations Dyno/ 87 Octane/ Naturally Aspirated / Underwater Exhaust
Imco Drive 1.36 Ratio / 2" Shorty
32-4bl Stock Bravo Prop
102 Gps @5300 Rpm @4000 Lbs Light............ws
will smith is offline
