Check out the diference: TRS vs #V's >
Old 06-12-2005 | 12:30 AM
kevinr's Avatar
Registered User
Default Check out the diference: TRS vs #V's
found this pic , was suprized . same boat new paint Also notice the prop rotation, this is the way Galen at SPEEDMASTERS told me to run them on the V's . Is this In or Out; been reading all the threads on prop directions.( lots of opinions).
Attached Thumbnails Check out the diference: TRS vs #V's-dsc00469.jpg   Check out the diference: TRS vs #V's-dsc00101.jpg
kevinr is offline
Old 06-12-2005 | 07:44 AM
bob
Charter Member #40
Default Re: Check out the diference: TRS vs #V's
TRS are spinning out. V's are spinning in. U-joint centerline to propshaft centerline on a TRS (25.12") vs a V (18.7")...V is 6.45" shorter.
bob is offline
Old 06-12-2005 | 03:49 PM
kevinr's Avatar
Registered User
You are right, put alot of study in before I mounted them. They are as high as I could put them,without pluging the transom & moving eng's up. X About 2" below the surface of the bottom. Takes forever to plane and slips real bad comming out of the whole,but once it comes over ,hold on...............any comments....................anyone
Boat: 88' Cig Top Gun
Full cabin ,all fiberglass
850Ft lbs per eng. Supercharged
12,000 lbs
17x29 cleavers 1.50:1 ratio
kevinr is offline
Old 06-12-2005 | 05:04 PM
nauti-buoy's Avatar
I have always wondered if a Speedmaster Drive would fit the TRS transom assembly. Can you still get parts for a number V drive??? by the way that is a sweet ride!!!
nauti-buoy is offline
Old 06-13-2005 | 06:33 PM
kevinr's Avatar
Registered User
No It wont, had to buy all of that, It will cover up the hole though and yes you can still buy V's and parts
kevinr is offline
Old 06-14-2005 | 05:34 AM
Have you got a speed on it yet?...just wondering what difference the drive change made....Fred
fred is offline
Old 06-14-2005 | 05:17 PM
kevinr's Avatar
Registered User
No not yet, having to catch up work in the machine shop
kevinr is offline
Old 06-14-2005 | 06:19 PM
Let us know when you do, would be interesting to see what difference it makes....is everything else motor wise the same as it was only the drive change?
fred is offline
Old 06-16-2005 | 09:18 AM
kevinr's Avatar
Registered User
Not exactly, old eng. 540ci single Dominator 600hp, New engines 540ci merlin heads 871 BDS's twin dominator 850hp
kevinr is offline
jeff32
06-08-2006 08:56 AM
chrisf
01-13-2006 04:44 PM
Audiofn
4
09-14-2004 09:14 PM
later
03-01-2004 09:11 PM
97BossHammer
07-12-2003 09:45 AM
