Water temp for a 454mag efi
Sounds your thermostat isn't present or it's not working. My efi 454's are fresh water cooled and specs say 160 degree stat--raw water stat is 140 degree.
Mine run aroune 150-160 at cruise (3200RPM) kick up to 170-180 at WOT.
Boat is a Formula SR357 with TRs drives and weighs over 10K. Engines are MarinePower 454 EFi using Arizona Speed TPI.
I'll ditto that.... Sounds like thermostat is stuck open and allowing continuous water flow to the engine thus preventing it from warming up to where it should be... The thermostat is an easy swap out..... just yell if your not sure how to..... Good luck!
