correct RPMs >
correct RPMs
correct RPMs
Old 06-18-2005 | 04:25 PM
Default correct RPMs
I just rebuilt my OMC 460 engine along with my 850 cfm holley carb. I am only maxing out at about 4000rpm. I should be hitting around 4800 rpms. Any idea where to start the problem solving? Is there a way to test to see if the secondaries in my carb are fully opening? does that sound like a possible cause?
24Baja is offline
Old 06-18-2005 | 05:40 PM
Default Re: correct RPMs
Timing advancing correctly??????
Griff is offline
Old 06-19-2005 | 01:35 AM
FOUNTAINATLAST's Avatar
We need more info, what rpm were you running before??? Are you using the same prop???? Make sure your throttle cable is adjusted correctly and opening up completely.....
FOUNTAINATLAST is offline
Old 06-19-2005 | 09:07 PM
I am using the same prop as before. Before the rebuild I hit around 4900 rpms
24Baja is offline
Old 06-19-2005 | 11:54 PM
Poorsche's Avatar
Are the throttle cables adjusted properly-otherwords are you really getting to WOT ? Went thru tha when I redid throtle levers and repowered--
Poorsche is offline
Old 06-20-2005 | 06:02 AM
push the throttle all the way open then remove the spark arrest/filter and look in the carb,,are all the butterflies vertical? 'Cause that's open. Then check that timing is doing what it should at speed.
cooltoys61 is offline
niceguy
9
05-08-2008 10:08 AM
Ken N
1
07-22-2007 12:51 AM
electrical1
5
07-28-2004 11:04 PM
electrical1
1
12-27-2003 11:22 PM
Ratchet
15
01-25-2003 10:39 AM
