454 mag mpi upgrade >
454 mag mpi upgrade
454 mag mpi upgrade
Old 06-27-2005 | 07:53 PM
dsandman6's Avatar
Default 454 mag mpi upgrade
Im pulling the motor to fix a cracked piston want to upgrade while its out does any body know best set up im not going crazy with it but everybody tells me i can do a heads and cam change that will wake the motor up thanks Randy
dsandman6 is offline
Old 06-27-2005 | 08:13 PM
Vinny P's Avatar
I hate the winter!!
Default Re: 454 mag mpi upgrade
You can't do any changes like that without remapping the ECU.
Vinny P is offline
Old 06-27-2005 | 08:29 PM
dsandman6's Avatar
Yea i thought I would have to do that just thought there might be a certain set up someone had tried
Old 06-27-2005 | 09:22 PM
Don't bother unless you are going to ditch the MPI. There are a few on here that have tried it, and it wasn't worth the $$. The MPI settup really limits the hp that you can make.
Possibly sell your motor and upgrade to a 454 mag or 502? Just my 2 cents worth....
Madmax is offline
Old 06-28-2005 | 06:44 PM
dsandman6's Avatar
Thats just the answer i needed to make my decision Thanks Randy
Old 06-28-2005 | 07:29 PM
If you have the 454MAG version, you can make about another 100hp or so with modded stock heads, cam, exhaust and ecu upgrade. There are a few vendors who will sell you the whole package.
Tyler Crockett, located in Michigan, 810-324-2720 came up with this upgrade several years ago for the 502mag, and it applies to the 454mag as well. Its a dyno proven package. You can send them the engine, or they can send you the parts.
Teague also has a kit as well.
Chase910 is offline
synack
22
04-28-2016 01:52 PM
mg503
Baja
14
04-03-2013 04:50 PM
cliff3466
1
03-09-2008 08:10 AM
Shore Thing
16
11-10-2006 03:42 AM
mr weazelle
0
02-08-2002 08:31 AM
