Speed out of a Procharged 25 Outlaw ? >
Old 06-30-2005 | 02:12 PM
Rocko C's Avatar
Question Speed out of a Procharged 25 Outlaw ?
I have a 2000 25 Outlaw with a Procharged (M3SC) and intercooled MCM 502 w/ Procharger competition fuel system. There are no other engine mods. I'm running a Bravo I 28p prop. and am topping out at 71.8 GPS trimmed up / no tabs. It gets up on plane immediately but I was just curious about the top end. Thanks everyone !
Rocko C is offline
Old 06-30-2005 | 02:49 PM
baja36ft's Avatar
Default Re: Speed out of a Procharged 25 Outlaw ?
What Rpm Are You Turning?
baja36ft is offline
Old 06-30-2005 | 02:50 PM
Rocko C's Avatar
Approx. 4800 RPM.
Rocko C is offline
Old 06-30-2005 | 02:54 PM
baja36ft's Avatar
At 4800 And 12% Slip You Should Be At 74.5 Or So Why
Don't You Try A 26 Bravo And Get The Rpm Up Some
I Guess The Rev Limiter Is At 5150?
baja36ft is offline
Old 06-30-2005 | 02:57 PM
baja36ft's Avatar
If You Can Get A Hydromotive Prop And Try That
A Friend With A 99 Outlaw (25)has One With A 502
And Runs 69.4 It Was Alot Faster Prop Then A
Bravo.
baja36ft is offline
Old 06-30-2005 | 03:24 PM
You should get more speed, have you asked procharger what prop you should run
steve1k99 is offline
Old 06-30-2005 | 04:01 PM
Rocko C's Avatar
No, not yet. I'll e-mail them next. Thanks.
Rocko C is offline
Old 06-30-2005 | 06:15 PM
A friend of mine has 82 MPH out of a 454, and skip the hydromotive it never held up to the torque of my procharged 502 H2x I run 89.8. A friend of mine helps design the kits if you need help!
JST2FST is offline
Old 06-30-2005 | 06:20 PM
Rocko C's Avatar
What's involved in the 'kit' ? What kind/size prop are you running on your H2X ?
Rocko C is offline
Old 06-30-2005 | 06:35 PM
I would think with 570+ HP you should
be running at least in the upper 70's
Do you have a boost gauge ?
And if so, how much boost are you showing ?
.....Fuel pressure too ???
JaayTeee is offline
