engine miss-firing >
engine miss-firing
engine miss-firing
Old 07-03-2005 | 09:42 AM
Default engine miss-firing
The engine will rev up fine, then I put it into gear and it will miss and back fire. I changed the plugs,the fuel filter and added dry gas, it is still happening
dennis obyrne is offline
Old 07-03-2005 | 12:44 PM
Default Re: engine miss-firing
What engine???
I would also change the cap and rotor and check the timing.
Griff is offline
Old 07-03-2005 | 01:10 PM
mr_velocity's Avatar
just putting it into gear at idle when when you try and get on it. Could be a lean backfire and not really missing. Just went through the same thing, sure acted like ignition but it was a lean backfire, rebuilt the carb and found a little snot of rtv in it.
mr_velocity is offline
wieland77
6
06-17-2008 12:17 PM
OSO News
Offshoreonly Industry News
0
02-19-2008 08:45 AM
mark30h
2
10-07-2006 03:23 AM
Harper220
12-13-2004 11:45 AM
Scott72
1
07-03-2003 12:05 PM
