Help, can you tell me what went wrong? >
Old 07-07-2005 | 12:16 AM
wantacat
Default Help, can you tell me what went wrong?
Ok so i was cruisin along on sunday in the Nordic. I was going about 40mph. I decided to hit the throttle and speed up, when I did there was a sudden loud beep. The boat slowly came to a stop and since the throttle was still engaged the motor just reved up. So I put the boat in nuetral and opened the engine compartment. Smoke was coming from the belt/pulley area and it smelled like a burnt serpentine belt. I check to see if my boat still goes into gear, which it does. It will go into gear but as soon as I give it some gas it does the same thing again. boat will go no where,rpms will jump up,motor will rev up and the smoke will start up again. I dont think its a spun prop.What do you guys think? Bearings?coupler? Impellar pump? One last thing, its a 496 with a bravo, boat has 55hrs on it and was just serviced. Oil change and drive was checked for alignment. thanks
Old 07-07-2005 | 01:05 AM
timewarp's Avatar
Default Re: Help, can you tell me what went wrong?
Sounds like you spun a coupler, if you had fried an impeller it would have overheated and you would still be able to move.
Caleb
timewarp is offline
Old 07-07-2005 | 01:44 AM
Strip Poker 388's Avatar
Rob
Caleb
If its the hub which it sounds like , I dont think a 496 has enough power to do it. I figure ya hit something or theres a engine misalimnt that made the hub spin.
Or the drive seazed [low oil?]and locked up the drive and spun the hub.
just guessing
Rob
Strip Poker 388 is offline
Old 07-07-2005 | 07:44 AM
DJD
Coupler!
DJD is offline
Old 07-07-2005 | 07:58 AM
BajaRunner's Avatar
Coupler.
BajaRunner is offline
Old 07-07-2005 | 08:06 AM
Milord's Avatar
Coupler
Milord is offline
Old 07-07-2005 | 10:47 AM
wantacat
I was still able to idle my boat back on to the trailer.
Old 07-07-2005 | 11:59 AM
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
My guess-Coupler
Similar thing happened to me on my Nova years back outside the Golden Gate.
Motor mount collapsed, caused engine/drive misalignment and spun coupler-towed in at 125.00 per hr by Sea Tow @ 5mph for 6 hours...ouch...Wife still reminds me on the expense not including yanking motor.
Good luck hope it works out 4u
GoCiggie31 is offline
Old 07-07-2005 | 12:01 PM
Hot Boat's Avatar
Team Dysfunctional
coupler
If it aint broke .... I can break it....
Hot Boat is offline
Old 07-07-2005 | 03:47 PM
Dean Ferry's Avatar
Veteran: Air Force
Drive coupler is spun.
Dean
Dean Ferry is offline
