Question  Fountain 27 or baja 275 >
Old 07-09-2005 | 12:01 PM
Default Question Fountain 27 or baja 275
Okay this will be my first boat fountain or baja.I do most of my boating on lake of the ozarks.Once in awhile i might pull a tuber. So what is your suggestion or maybe a different Name brand of Boat Thanks this is my first post Thanks For the Help
firemedjoe is offline
Old 07-09-2005 | 04:25 PM
Default Re: Question Fountain 27 or baja 275
Both are good boats. The Fountain is probably going to be a bit more money. The baja will be a bit bigger and handle the water a bit better. But that's my politically correct 2 cents
Gary C is offline
Old 07-09-2005 | 05:19 PM
Mentalpause's Avatar
Drive both and make your pick. I've been driving LOTO for a long time. Either are going to be a rough ride on weekends. Both will be OK for during the week, but just OK during summer months.
Mentalpause is offline
Old 07-09-2005 | 07:30 PM
TEAMBAJA's Avatar
Ditto. (make that 4 cents)
TEAMBAJA is offline
Old 07-09-2005 | 07:35 PM
eMotiondriver's Avatar
If both equipped with the same HP the Fountain will be faster and handle the bigger water. The Baja may have better amenities and be more comfortable. Your call both good.. My .02.
eMotiondriver is offline
Old 07-09-2005 | 07:54 PM
Try to test drive both boats with the same power you plan on buying then decide.
CasinoRunner is offline
Old 07-09-2005 | 08:27 PM
Outdrive1's Avatar
Masher touches my
They are both well made boats, I agree that the Fountain will be faster, you'll sacrifice some space for the speed though. As far as pulling tube? Not with the Fountain........ I know my business partners Fountain can barely get on plane with 4 people in the back of it, he has to have everybody move forward in the cockpit before it will roll over, even with trim tabs. This is no BS, I've been behind his boat and watched it. That's with a 496ho Bravo drive and 4 blade bravo 1 24 pitch prop. The boat is faster than most single motor 496 boats but it does not plane well. If you are going to have a bunch of people riding in there trying to pull a tube you'd better be tall enough to see over that beak straight up in the air........
I'd still take the beak over the Baja though (I don't pull tubes anyways)..........
Outdrive1 is offline
Old 07-09-2005 | 08:32 PM
SOX's Avatar
SOX
Semper Fi
How about a 288 Sunsation?
http://www.sunsationboats.com/mod288.htm
I haven't taken a ride in one but I always hear good things about them and they look great! my .02
SOX is offline
Old 07-09-2005 | 08:45 PM
fountainatlast, are your going to let him talk about your boat like that...
firemedjoe, I will have to go with the Baja...
tpmarine.com is offline
Old 07-09-2005 | 08:48 PM
28 cig
dreamer is offline
