How to wire kill switch? >
Old 07-13-2005 | 05:29 AM
Default How to wire kill switch?
Finished uprading my twin Daytona. Believe it or not did not come with a kill switch. I bought one from Fred, but I'm wondering if it is the right one? Are there kill switched for twins or can I wire both through a standard kill switch? Do I wire it through the power switch on the key?
SkiDoc is offline
Old 07-13-2005 | 06:23 AM
bowtie's Avatar
Default Re: How to wire kill switch?
There are kill switches for twins that use a diode. Other wise you need 2 single switches.
bowtie is offline
Old 07-13-2005 | 09:59 AM
FOUNTAINATLAST's Avatar
Wire it through the hot wire off the ingnition switch to the engine, therefore causing the switch when turned off cutting power to the motors, hope this helps.
FOUNTAINATLAST is offline
Old 07-13-2005 | 10:05 AM
Depends: do you have stock ignition or MSD?
I believe for MSD use the white wire out of the ignition box, run it thru a kill switch (that closes the circuit when the cap is pulled), and then to a ground. Also with MSD I think that you can run both engines to one switch, since you're grounding the circuit(s).
There's info on MSD's web site for "theft prevention wiring" to verify.
Due
Dueclaws is offline
Old 07-13-2005 | 01:05 PM
p4-33's Avatar
I use a switch from Saf-T-Stop. They have a single throw, dual pole switch specifically designed for twin applications, and comes with lanyards. I've not had any issues passing tech inspection at race sites, so they are race-worthy.
I have three of these across my dash for each crew position. I tapped into my red ignition wire and made a "series loop" thru one side of each switch, and back to the red ignition wire. Repeated again for other motor, other side of each switch.
I like removing ignition power to the motor at the key switch, especially if you have an electric fuel system. Cut the power to the ignition and everything shuts down, not just your MSD box. Fuel system shut-off is a tech requirement for the sanctioning bodies.
Search your favorite search engine for "Saf-T-Stop Switch KS-22" by T&H Marine. Make sure it's the dual i/o model.
CP Performance carries them, too.
Good luck,
Brian
p4-33 is offline
Old 07-13-2005 | 03:59 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Anybody make one for three engines/one lanyard?
waybomb is offline
Old 07-13-2005 | 09:28 PM
Thanks for the replies. I have MSD ignition, electric fuel pumps that are wired to shut off with no oil pressure. If I could wire it at the switch it would be much easier. Would it still work running the kill switches through the hot wire on the ignition switch?
SkiDoc is offline
Old 07-13-2005 | 09:48 PM
kmiller's Avatar
You would have to use three realys and one kill switch for tripples... I can tell you how to wire them if needed...... Kyle
kmiller is offline
Old 07-14-2005 | 09:17 AM
p4-33's Avatar
Yes, this is the same setup I'm running: MSD, elect fuel, oil pressure switch to remove fuel system power via a relay when oil pressure goes away.
"Killing" power to the ignition at the red ignition lead on the key switch will shut down the MSD box, as well as the fuel system.
Brian
p4-33 is offline
Old 07-14-2005 | 05:35 PM
waybomb's Avatar
Ahh, didn't think of that! I can wire that up. I'll use the normally open contacts. Thanks!
waybomb is offline
Fenderjack
0
08-30-2007 03:25 PM
BLAZE
Boating Safety
1
07-10-2007 09:56 AM
Hang Time 27
12-29-2003 10:10 PM
dyno
07-25-2002 07:14 AM
sheikman
1
05-27-2002 09:45 AM
