Go Back  Offshoreonly.com > Owners Forum > Sunsation
single ski tow eye on rear of 288 >
Old 07-14-2005 | 01:17 PM
Chris288's Avatar
Default single ski tow eye on rear of 288
anybody do it ?? where did you put it ??? Took a look behind my H.O. and things look a bit flimsy uder there for the stress of a ski hook, plus there is the vent in the middle... ??????
Chris288 is offline
Old 07-14-2005 | 02:46 PM
Canada Jeff's Avatar
Default Re: single ski tow eye on rear of 288
Maybe you can find on old arch off of a Sonic or somthing, make her into a wake board boat ;-)
Canada Jeff is offline
Old 07-14-2005 | 03:21 PM
DaveSunsation's Avatar
Chris,
We put them on all the time, but first we bulk up the area where we put them with more glass and laminate in a 1/2 in piece of marine plywood. We put them on the starboard side of that center vent. Keep in mind, the cleats work real well, folks secure a line between the two cleats and center off that for pulling.
David
DaveSunsation is offline
Old 07-15-2005 | 08:11 AM
Chris288's Avatar
Dave,, Thanks for cabin door stopper,,, and the advice....
Chris288 is offline
Old 07-15-2005 | 10:13 AM
Along the lines of what Dave mentioned, I purchased a waterski bridle this year to eliminate the offset of the stock ski eye. Basically a big "Y". Attaches to the rear cleats and hangs clear of the swim platform.
Check out Bart's or Ski Limited, costs about $30, works well.
Swift1 is offline
Old 07-15-2005 | 12:44 PM
KN
Hey Chris this is what I have, You can pull from just one, pull two skiers. or use a water ski bridle like Swift1 mentioned that works great. I would be hesitant about using your cleats, were they are reassessed you may get some chaffing. My cleats have also loosened up with regular use, and I cant get to them to tighten them up.
Kirk
KN is offline
KN
...... Chris I cant post the pictures for whatever reason I will e-mail them to you. File is to large, and I don't know how to down size it.
Kirk
KN is offline
Old 07-15-2005 | 01:28 PM
Kirk,
You should be able to reach the polly nuts in the back with a wrench and have someone else tighten the screws.
7/16 box end
Old 07-16-2005 | 12:41 PM
Mentalpause's Avatar
Originally Posted by DaveSunsation
Kirk,
7/16 box end
I mounted my box end on a 2 foot long 1x2. It worked great.
Mentalpause is offline
Wazzup Racing
OPA/The Jersey Boyz
3
05-15-2007 04:33 PM
Michael1
7
05-07-2007 12:21 PM
Michael1
3
03-05-2007 10:06 PM
VIPER7
4
09-08-2006 10:02 AM
completelymobile
05-31-2004 07:54 AM
