Rough Running 454 Mag?????help >
Old 07-15-2005 | 02:55 PM
ITLLFLI's Avatar
Default Rough Running 454 Mag?????help
CFD5 is down at lake cumberland with his apache and is having a hard time with one of his motors. The symptom is it will start and run fine for a second then run rough like it is out of fuel.
He has done:
new fuel pump
switch carb from other motor
switch ignition from other motor
inspected for water in fuel
Any other ideas?
Thanks!
ITLLFLI is offline
Old 07-15-2005 | 03:58 PM
Default Re: Rough Running 454 Mag?????help
Has he checked the timing? When was the last time he changed plugs? If it is indeed running out of fuel it could be an obstruction in his tank pick-up. Good luck.
Craig
WETTE VETTE is offline
Old 07-15-2005 | 04:47 PM
ITLLFLI's Avatar
Craig
Craig,
Thanks! Him and Hadley are down there wrenching on it now. They changed the plugs and have run fuel out of the "out" side of the fuel pump to make sure of psi.
They/we are stumped!
Oh yeah...the houseboat generator pooped out also!
ITLLFLI is offline
Old 07-15-2005 | 05:08 PM
Vinny P's Avatar
I hate the winter!!
Maybe it jumped time. Take a compression check. How old is the motor?
Vinny P is offline
Old 07-15-2005 | 06:19 PM
GOODT's Avatar
How About The Coil??????
Joe
American Performance Marine
410 573 0057
GOODT is offline
Old 07-15-2005 | 06:21 PM
GOODT's Avatar
Coil Heats Up And Shorts !!!!
Joe Apmboats.com
GOODT is offline
Old 07-15-2005 | 06:43 PM
checked the dist. for condisation.
fbc25el is offline
Old 07-15-2005 | 06:52 PM
GOODT's Avatar
STILL SOUNDS LIKE MAYBE COIL BAD CAP WILL ALWAYS BE BAD NOT GET WORSE AS U RUN
JOE HP TECH
AMERICAN PERFORMANCE MARINE
FOUNTIAN,CIGARETTE,SONIC, ACTIVE THUNDER
[email protected]
GOODT is offline
Old 07-15-2005 | 10:00 PM
Outdrive1's Avatar
Masher touches my
Sounds like you've covered all the bases on the fuel issue. Did you clean the screen at the intake of the carbs? Those carbs sometimes get clogged right there. Also you could switch coils to test them and switch ignition modules. Do one at a time so you can narrow it down. My guess would be the ignition module.
Outdrive1 is offline
Old 07-16-2005 | 07:35 AM
carney's Avatar
Do a leak down test ,It will tell you what kind of shape the motor is in, then move on to step two. Scratch your head.
carney is offline
