OK Baja owners check this out!!! >
Old 07-18-2005 | 04:36 PM
Default OK Baja owners check this out!!!
I upgraded the gauges and controls on my 322...what do you think?
I have decided to go with a yellow and purple color scheme to match the yellow & purple graphics.
Everything related to the port side motor is done in yellow and everything related to the starboard side is done in purple. All white gauges are neutral, I may have to add a little color to them later.
Attached Thumbnails OK Baja owners check this out!!!-dsc00198.jpg   OK Baja owners check this out!!!-dsc00196.jpg   OK Baja owners check this out!!!-dsc00197.jpg
tpmarine.com is offline
Old 07-18-2005 | 04:43 PM
32 caliber's Avatar
Default Re: OK Baja owners check this out!!!
looks like from the pics that the two primary colors on the side of the boat are green and yellow???
32 caliber is offline
Old 07-18-2005 | 04:49 PM
actually the boat graphics are teal, purple and yellow, but teal is not my favorite so I decided to go with the purple and yellow...
Old 07-18-2005 | 05:30 PM
JasonSmith's Avatar
what does it take to install the gauges for drive temp? I am assuming that is what the one on the right top is with the 2 needles, or is it a pyrometer?
BTW Don, the speedo I got from you is perfect!
Thanks again!
JasonSmith is offline
Old 07-18-2005 | 06:54 PM
Thanks again!
Your welcome, glad I could help...
The gauge in the upper right is a pyrometer...neither gauge (pyro or drive temp.) is all that difficult to install it just takes a little while. In fact, with the exception of having to run the hose through the transom, hooking up a drive temp. gauge is pretty easy. Livorsi's senders are designed to mount in the oil vent hole.
Take care,
Don Baca
stecz20
Cigarette
247
03-17-2012 09:16 PM
Vyper340
Powerquest
97
12-13-2005 08:51 PM
Need-the-Speed
Baja
0
06-17-2005 02:19 PM
tpmarine.com
Baja
9
04-15-2005 10:08 AM
JBOUTLAW25
Baja
7
12-20-2004 03:20 PM
