Merc Shift Cutout Switch >
Old 07-19-2005 | 01:00 PM
Plum_Crazy's Avatar
Default Merc Shift Cutout Switch
I just isolated intermittant ignition problems I've been having to the shift cutout switch on my '88 Baja Sunsport 196. The Merc part number is 39670A28. My local marina looked it up and it's not available anymore. The service bulletin states that the replacement kit only works with a new trim pump. Does anyone know how/why the trim pump would be affected by this switch? Is there a suitable non-Mercruiser replacement switch out there?
Plum_Crazy is online now
Old 07-19-2005 | 01:25 PM
Mbam's Avatar
Offshoreonly Advertiser
Default Re: Merc Shift Cutout Switch
The new shift bracket doesn not have a provision for a reverse lock valve. The RLV was not used on anything I can think of past 1982 or so. We keep the kit PN 86436A1 on the shelf, you can order here if you want:
http://www.mercruiserparts.com/partsByNumber.asp
Mbam is offline
Old 07-19-2005 | 01:39 PM
Plum_Crazy's Avatar
That would be good news if I can use that kit. I just have to verify I have the right trim pump.
jdub
13
04-10-2011 10:59 PM
PARADOX
10
02-14-2008 09:30 AM
HPJunkie
Drives and Lower Units
6
01-27-2008 11:20 AM
BRIAN73
3
04-22-2005 02:01 PM
imq707s
2
04-05-2002 07:30 PM
