boats been in the water for 4 weeks >
Old 07-20-2005 | 10:58 AM
Wild's Avatar
Default boats been in the water for 4 weeks
I know I know, It was my only option
now it is on the lift, the bottom has little things growing on it and the drives are covered.
What is the best product to get this off with out hurting crome pices, or rubber, or paint, or wax
Wild
Wild is offline
Old 07-20-2005 | 11:35 AM
BLee's Avatar
Charter Mod
Default Re: boats been in the water for 4 weeks
I'd start with a powerwasher to remove the "slime". When you get all of that off there will probably be a yellowish stain from the waterline down. There are a few different acids out there that will remove the stain and are safe for use on fiberglass and metals. I have used a product called "Zing" in the past. You will want to dillute it, and don't leave it on there very long or you CAN damage the finish on your fittings. Afterwards it's a good idea to rewax the hull to recondition it.
It's a SORRY-ass job. Have fun!
BLee is offline
Old 07-20-2005 | 11:38 AM
jawbreakerkid's Avatar
Wild- My slip w/ lift was sitting empty....you had a choice!
jawbreakerkid is offline
Old 07-20-2005 | 11:39 AM
Ron P's Avatar
Enjoy the show
Pressure wash then use On/Off - the stuff with the skull and crossbones on the label. White bottle, orange label.
Just don't breathe it or touch the stuff. Wear gloves and a mop that you plan to throw out. Nasty job, but it must ALL come off.
Ron P is offline
Old 07-20-2005 | 11:46 AM
Wild's Avatar
does vinigar help cut the crud????
JBK, i had it on Ash's slip, then he needed it, and i totaly forgot about yours. Dang
I will take the pwasher to it, then start scrubbin
Wild is offline
Old 07-20-2005 | 11:59 AM
fund razor's Avatar
The On/Off stuff is basically toilet bowl cleaner.
I would dilute it and wear GOOD rubber gloves, eye protection and a mask.
Stand upwind at all times.
fund razor is offline
fund razor's Avatar
By the way... 4 weeks.... that's almost a whole season up here.
Old 07-20-2005 | 12:06 PM
t500hps's Avatar
21 and 42 footers
Used ON/OFF many times..... I keep a brush with a long handle specifically just for that product. Power wash off what you can and mix ON/OFF 50/50 with water in a bucket. Wipe the hull down let sit just a minute or 2 and wipe it down again. (scrubbing doesn't help much) Re-apply if needed, but that's all I've ever needed. This stuff will take EVERYTHING off the hull so re-waxing is necessary.
t500hps is offline
Old 07-20-2005 | 03:46 PM
BLee's Avatar
Charter Mod
You can also use a cheap bug/weed sprayer. It makes it a little easier to get into tough areas. Like everyone else said, don't let it get in your eyes and avoid your skin. It will itch at first, then burn like hell.
BLee is offline
Old 07-20-2005 | 03:52 PM
Strip Poker 388's Avatar
Rob
Doesn't the acid in these cleaners etch the gel coat and make it porous and susceptible to getting stained easier the next time????
Do they make a cleaner with out the acid that works to get out the yellow stains??
Rob
Strip Poker 388 is offline
