Weekend Damage Report
Old 07-23-2005 | 05:54 PM
Default Weekend Damage Report
Damnit! I should have taken OSO member Chuck's offer to go to Lake Champlain with him today. At about 3:00 my cousin arrived from Long Island and we were going to take out the Skater for a cruise up the lake. When I fired up the starboard engine it made an AWEFFUL racket. I said, "boy that doesn't sound good" . We headed out and eased it up on plane. Cruising along at about 50 or 60 the starboard motor was light on RPM's. We headed for home hoping it was just a bad plug or coil. I felt the plugs and one was barely warm. I pulled it, and it looked like it was sand blasted! All the other plugs looked GREAT! The top of the piston looked sand blasted as well. I was so disgusted we pulled it out of the water and I covered it up. Maybe I will pull the head tomorrow to look inside and see how bad it is.
Hopefully, it just burned a hole in the top of the piston and damage will be mild. Hopefully just a piece a dirt in the carb or similar. I bought these powerheads for longevity and run the fuel oil mixture rich, the jets fat, and don't run her WFO. Sometimes, it just ain't your day!
Shane is offline
Old 07-23-2005 | 06:12 PM
Strip Poker 388's Avatar
Rob
Default Re: Weekend Damage Report
Hopefully ya didn't get a cylinder wall too If its that rich maybe its a intake leak?
Good luck
Rob
Strip Poker 388 is offline
Old 07-23-2005 | 08:03 PM
GO4BROKE's Avatar
Good luck with it Shane! Intake leak is a likely culprit. If it makes you feel any better so far this year I have spun a coupler and threw a blade on a labbed prop. As if fuel isn't costing enough this year! Oh well, if it weren't expensive it wouldn't be a speed boat.
[img][/img]
GO4BROKE is offline
Old 07-23-2005 | 08:41 PM
Just got home........starboard drive.....kaboom
actually wasn't bad was on my way home and only about 2 miles away.
and I have another brand new one in the garage
just don't have the ambition to change it to go back out tomorrow.
today was first day in this year.........so something had to break.
Mike 35 Fountain is offline
Old 07-23-2005 | 11:24 PM
Tinkerer's Avatar
Any time you have an engine that just doesn't sound or run right -- DON'T keep running it -- SHUT IT DOWN AND FIND OUT WHAT IS WRONG.
It is a lot easier on the wallet that way.
Tinkerer is offline
stecz20's Avatar
blew a starboard drive myself... other than that is was a great day...
stecz20 is offline
Old 07-23-2005 | 11:41 PM
ratman's Avatar
sure sounds reasonable to me. run it til it blows can be very pricey
ratman is offline
OldSchool
06-03-2006 11:36 AM
docmanrich37
07-03-2005 08:20 AM
VelocityMike
04-10-2005 10:25 PM
