Hdyromotive P5-X >
Hdyromotive P5-X
Hdyromotive P5-X
Old 07-27-2005 | 01:01 PM
throttleup's Avatar
Default Hdyromotive P5-X
I am happy to say that the Hydromotive P5-X props are now available in a 23P and 24P!!!!!!!!!!
This is great news for those of you running 26P Bravo I porps that had some interest in 5B'x.
Julie
throttleup is offline
Old 07-30-2005 | 07:48 AM
boathead's Avatar
Default Re: Hdyromotive P5-X
Hi Julie,
I have a question for you, I presently have Merc Bravo I 4 blade 28P props (inward turning) on my 2000 Powerquest 380 Avenger(approximate weight fully loaded is 11,500lbs.).
X dimension is 17 1/2"(or about 4" below the hull) Top speed with my dinged up props is 72-73mph.
I would like to get another set of props that will hold even better in rough water, would the hydromotive P5 X's work here? Would I need to go down in pitch with this prop ( currently running to the rev limiters), I am much more concerned about rough water performance than top speed!
Thanks, Paul
boathead is offline
Old 08-02-2005 | 01:57 PM
throttleup's Avatar
Yes, Paul it is possible the Hydromotive P5-X may achieve your goal. You will indeed drop 1 inch of pitch from the actual pitch of your current propeller. So in Your case the Bravo I 28P is actually approx. a 27P so you would need a 26P P5-X. They are readily available.
Julie
Old 08-08-2005 | 01:18 PM
MrCIG's Avatar
Charter Member#330
Julie do you have any 23 Demo's yet? I have Brian's 25 P5X's turning them 4700 at wot. Do you think the 23's would bring me to 5000.
Mark
MrCIG is offline
Old 08-08-2005 | 03:03 PM
throttleup's Avatar
Hello Mark,
The 23P P5-X props should runn 400 RPM higher than Brian's 25P, assuming his are stock. Unforunatly we don't have them for testing purposes, but this is what it sounds like you need.
Julie
