Fuel lines
Old 07-30-2005 | 08:49 AM
ofshore's Avatar
Default Fuel lines
What do you guys use for your fuel lines coming in and out of the fuel pump? Mine are hard copper tubing and I'd like to get something flexible so if I change something I don't have to make new lines.
ofshore is offline
Old 07-30-2005 | 10:16 AM
Payton's Avatar
Charter Member #927
Default Re: Fuel lines
Summit sells a flexable SS kit with all the fittings you need, from a couple of different manufacturers. Just cut to the length you need and install the ends. Be sure to use some sort of lubs to get the fittings onto the lines, it is much, much much easier.
Payton is offline
Old 07-31-2005 | 09:30 PM
ofshore's Avatar
thanks guys I'll check out summit and see what they have.
ofshore is offline
dukenrock
02-01-2007 09:29 PM
tewks
05-18-2006 10:40 AM
electrical1
11
06-26-2005 11:58 PM
Formula29
12
04-09-2004 11:59 AM
RonS
08-19-2003 08:15 AM
