torque specs >
torque specs
torque specs
Old 07-31-2005 | 03:53 PM
KCHOTBOAT's Avatar
Charter Member #737
Default torque specs
which torque specs would you use for heads? ARP head bolts calls for 65ft pounds and merc 75ft pounds.
KCHOTBOAT is offline
Old 07-31-2005 | 04:59 PM
Default Re: torque specs
I always torque the arps to 75 regardless and make sure you seal the threads well with a good thread sealer such as permatex#2.
MESABALANCING is offline
Old 08-01-2005 | 01:01 AM
ARP's recommended torque settings are usually lower because they tell you to use their moly lube which according to them gives about the same amount of bolt stretch with 10 ft-lbs or so less torque. For example, for the ARP head studs I'm using, they recommended 70 ft-lbs with ARP moly lube (for iron heads) and 85 ft-lbs with oil.
They only recommended 65 ft-lbs w/ moly lube for Alum. heads, so I followed AFR's instructions and torqued mine to 75 ft-lbs in 15lb increments.
HARDCORE A/O is offline
Old 08-01-2005 | 09:40 PM
When I redid the top half of my 525SC, I used new ARP head bolts, the ARP sealant/lube and their torque specs. No problems after 50hrs.
Griff is offline
Old 08-02-2005 | 06:21 AM
Pwrbt33's Avatar
Talking Re: torque specs
Just like MESA said, use a good sealer like #2 Permatex and use Moly lube with oil under the head bolts and washers. Make sure also you torque in steps as well. After sitting for about 20 minutes or so I usually go back and loosen one bolt at a time and re-torque to its final torque speck. This helps in bolt stretch and tightness. Some do and some don't. Its seems to work for me so I keep doing it.
Good luck.
John
Pwrbt33 is offline
Dono
6
07-30-2005 01:15 AM
thunderusone
3
05-15-2004 06:19 PM
KCHOTBOAT
3
04-25-2004 04:22 AM
RCM255
3
07-12-2002 10:31 AM
dyno
6
07-11-2002 11:25 PM
