Alpha one upgrade >
Alpha one upgrade
Alpha one upgrade
Old 08-03-2005 | 08:40 AM
racer-x6's Avatar
Default Alpha one upgrade
I'm upgrading a Alpha I gen one to a Alpha I Gen Two. The things I knoe I need to change are:
Outdrive
Complete gimble housing outside
Inner plate
What else will i need to change?
Shift plate
Exhaust "Y"
Coupler housing
Hyd. steering cyl.
Also I think the hole paterns the same, is this right
Thanks for you help.
racer-x6 is offline
Old 08-03-2005 | 12:13 PM
GOODT's Avatar
Default Re: Alpha one upgrade
you are correct the only thing that you will need to add that you didnt mention is a drive res bottle
GOODT is offline
Old 08-03-2005 | 12:57 PM
racer-x6's Avatar
SO I DO NEED TO CHANGE THE
Shift plate
Exhaust "Y"
Coupler housing
Hyd. steering cyl.
OR NOT
racer-x6 is offline
Old 08-03-2005 | 03:24 PM
GOODT's Avatar
No You Dont Need To, All That Should Be The Same
GOODT is offline
Old 08-03-2005 | 03:28 PM
racer-x6's Avatar
COOL THANKS,
YOU DON'T HAPPEN TO HAVE A GOOD USED SET-UP DO YOU?
racer-x6 is offline
Old 08-03-2005 | 04:20 PM
GOODT's Avatar
No Sorry But You Can Try Calling Paul At 410-855-5656 At Haurbor North Marina He May Just Tell Him Joe From American Performance Told U To Call
GOODT is offline
Old 08-03-2005 | 04:27 PM
racer-x6's Avatar
JOE,
THAT # IS NOT IN SERVICE
ERIC
racer-x6 is offline
Old 08-03-2005 | 05:43 PM
GOODT's Avatar
Sorry 410-885-5656 Just Noticed My Mistake
GOODT is offline
Old 08-03-2005 | 07:35 PM
Pwrbt33's Avatar
Talking Re: Alpha one upgrade
If you do the swap, make sure the speedo hole in the new transom assembly has a plug in it. Would hate to see you hose your engine bay down with salt water. Unless your going to use it.
Pwrbt33 is offline
Old 08-03-2005 | 07:54 PM
GOODT's Avatar
John,
Good Call Forgot About The Speedo Pick Up!!!!
GOODT is offline
Ken N
Drives and Lower Units
2
09-10-2007 11:03 AM
srracer
2
04-20-2006 03:49 PM
cloudmaster_321
34
04-07-2005 09:38 PM
Elite Marine
12
08-21-2003 09:16 PM
